[Qgis-developer] Cad-Input for QGIS prototype
Saber Razmjooei
saber.razmjooei at lutraconsulting.co.uk
Mon Jan 27 08:18:08 PST 2014
Auto-trace plugin might be of your interest as well. It's ready and should appear in QGIS plugin repo soon.
Cheers,
Saber
-----Original Message-----
From: qgis-developer-bounces at lists.osgeo.org [mailto:qgis-developer-bounces at lists.osgeo.org] On Behalf Of Andreas Neumann
Sent: 27 January 2014 15:35
To: qgis-developer at lists.osgeo.org
Subject: Re: [Qgis-developer] Cad-Input for QGIS prototype
It looks very useful.
I also think this should be in the core of QGIS - or before that it would be nice if it could be integrated in Bernhards Ströbl DigitizingTools plugin.
I hate it when I have to enable 5 different plugins to get a decent digitizing environment. And when I teach QGIS to new users it is most confusing if functionality is spread among too many plugins.
So if possible - please integrate such functionality in existing plugins or into QGIS core rather than starting a new plugin.
Thanks a lot for your efforts.
Andreas
Am 27.01.2014 10:52, schrieb Bernhard Ströbl:
> Hi Antonio and Olivier,
> I will comment below.
> Olivier, thanks for the move.
> Am 26.01.2014 06:05, schrieb Antonio Locandro:
>> Hi Oliver, thanks for copying me in this email
>> Let me tell you that I have installed your prototype and tested it. I
>> do think something like this is needed and I do like the fact that it
>> works with other tools directly. I like the fact it gives you
>> guidelines of what it will do like in CAD software. I think it would
>> be nice to add also the possibility to use right clicks for actions
> I have not tried your plugin but watched the video. Looking at
> defining an angle it should be definable relative to a) the last
> segment b) North
> c) another (helper) point
>> To address your points
>> 1) yes this feature is needed in QGIS, other COTS software have this
>> functionality as Advanced Editing and I do rely heavily daily on this
>> type of things for my job and is amongst several reasons why we cant
>> switch for QGIS. I know the main user base of QGIS probably use it
>> only for analysis but for some of us we need to digitize precisely
>> coordinates based on field data or to create specific features.
> would be useful here, too
> Although I think most CAD functions for which currently nothing
> similar is available in QGIS are for construction I still think, it
> would be great to have them. (Of course not those to create 3D screws
>> I would vote to keep to make it part of core as Advanced Tools or
>> something, I also think it would be quite nice to merge the different
>> CAD-like tools into one and have all this contributors who made this
>> individual plugins work as a team. Resources are not always available
>> and to join forces to me seems a better approach
> The digitizingTools plugin is trying a similar approach, namely to
> combine efforts and present _one_ plugin.
>> 2) I would leave that for developers
>> 3) I cant code, at least I am not at that level. I am just learning
>> python and it might take some time to achieve a level to make
>> something useful. I can however test the plugin and suggest features.
>> I think the best way is to add issues in the github repository of
>> bugs, improvements etc.
> I am working more or less continuely on digitzingTools (if need arises).
> I can support in Python coding.
>> 4) Some ideas to start with, I will add them to github so you have
>> them there also. I understand it is a prototype to see if it gathers
>> traction but I feel it will
>> - snap to midpoint (snapping options to behave like in CAD software)
> more easy control over snapping in general: currently snapping has to
> be set for each individual layer seperately: switch snapping on/off
> completely, set snapping behaviour for all layers at once (segment,
> node), additional snapping options needed: snap to middle of line,
> snap perpendicularly
>> - Add trim line
> +1
> trim two lines so they form a corner
>> - Add extend line
> digitizingTools already offers continuing digitizing of a line (though
> not CAD like in prolonging the line in the direction of its last
> segment) would be great to extend several lines until they meet
>> - Add ability to create arcs e.g. Tan Tan Radius; select center and
>> add radius
> question would be how this is to be stored in GIS format
> - general: provide a means to move the map while any digitizing tool
> is active. possible solutions
> a) shift/ctrl + drag
> b) add scrollbars (looks arkward but users at once know what to do)
> my 2cts
> regards
> Bernhard
>> - Add the ability to draw by deflection angle apart from
>> perpendicular and parallel
>> - Maybe add the possibility to add x,y in DMS, DM, DD when working in
>> WGS84
>> - The plugin already adds the function to calculate within fields. I
>> think one useful thing in length is that by default it is m (or the
>> epsg default unit I guess ft might be for some) and that you can add
>> different units by adding the appropriate abbreviation like in other
>> COTS e.g.
>> 18 ft
>> 1 NM
>> 1 SM
>> From: olivier.dalang at gmail.com
>> Date: Sun, 26 Jan 2014 03:08:27 +0100
>> Subject: Cad-Input for QGIS prototype
>> CC: diego.gnesi at gmail.com; Stefan.Ziegler at bd.so.ch;
>> bernhard.stroebl at jena.de; antoniolocandro at hotmail.com
>> Dear list,
>> Some times ago, on this list, we discussed[1] about real CAD-like
>> input for QGIS, and since I do myself long for such a feature very
>> much, I'd like to reopen that discussion by *proposing a python prototype*.
>> I know there are already a few plugins aiming in that direction
>> (CadTools, ImprovedPolygonCapturing, NumericalInput and a few other).
>> They provide the functionality, but not the ease of use you can find
>> in CAD packages.
>> One key aspect is that they are all specific tools, and do not work
>> The prototype is inspired from Archicad's input method which allows
>> to combine numeric input with mouse input in a very efficient and
>> flexible manner, to get the best of both.
>> It is currently very raw and not well tested at all... It also relies
>> on a lot of dirty hacks, since the python API is not well suited for
>> this type of plugins (have a look at the README on the github page
>> for more details).
>> *DEMO (video) : https://vimeo.com/85052231* *GITHUB (readme,
>> download...) :
>> https://github.com/olivierdalang/CadInput*
>> Please, tell me what you think :
>> 1) Concept
>> - Does this kind of input seem interesting to you ?
>> - How does it fit in a GIS-environment ? Since it comes from a CAD
>> environment, maybe it's more suited to designing than digitizing.
>> 2) API/Core modifications (read
>> https://github.com/olivierdalang/CadInput#technical-notes )
>> - How do you see the suggested improvements ? Are they feasible ?
>> - Does developing this as a python plugin make sense, or does it have
>> to be in the core from the start ? (I'm not familiar with core
>> developing)
>> 3) Collaboration...
>> - Is anyone of you currently working on the same topic ?
>> - Would anyone have some time/interest in collaborating on this feature ?
>> 4) Other ideas are welcome !
>> Thanks for your attention,
>> Olivier
>> [1]:
>> http://osgeo-org.1560.x6.nabble.com/Make-QGIS-interact-with-LibreCAD-
>> td5048565.html
>> (To those from this discussion I cc'ed, I though you may be
>> interested, I hope you don't mind)
>> __________ Information from ESET Mail Security, version of virus
>> signature database 9338 (20140125) __________
>> The message was checked by ESET Mail Security.
>> http://www.eset.com
> signature database 9340 (20140126) __________
> http://www.eset.com
> Qgis-developer mailing list
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed.
If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the
individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately
by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. If you are not the intended recipient you are notified
that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
Whilst reasonable care has been taken to avoid virus transmission, no responsibility for viruses is taken and it is your responsibility to carry out
such checks as you feel appropriate.
Saber Razmjooei and Peter Wells trading as Lutra Consulting.
