[Qgis-developer] Lidar data into QGIS
Stefan Keller
sfkeller at gmail.com
Fri Jan 31 00:22:37 PST 2014
2014/1/31 A Huarte <ahuarte47 at yahoo.es>:
> Although I know you're going to try it in Vienna, I would like to recover
> the idea of creating a new type of layer (eg QgsPointCloudLayer) that
I usually also tend towards just doing - but this time, with LIDAR
it's probably a good advice to think and discuss first
It's really a tricky thing. See e.g. Paul Ramsey's Talk at FOSS4G
2013, Birmingham:
http://elogeo.nottingham.ac.uk/xmlui/bitstream/handle/url/186/pgpointcloud-foss4-2013.pdf
2014/1/29 Howard Butler wrote:
> I think the first question to answer for a QGIS point cloud capability is to define
> what it will do. Is it a renderer/viewer? Product processing pipeline? Everything?
> I think it is important to keep the scope limited for the first few attempts to
> feel out the problem.
Exactly.
--Stefan
P.S. BTW there is another "battle field" over at the format definition
side which currently needs some attention:
"LIDAR Format Wars..." http://boundlessgeo.com/2014/01/lidar-format-wars-2/
> inherits from QgsVectorLayer to provide all the basic vector functionality
> (including a new simplification of proximity to fast rendering), and add
> extra capabilities for these data types: output rasters, 3D profiles, 3D
> visualization in plugins ...
> Best Regards
> Alvaro
> ________________________________
> De: Paolo Cavallini <cavallini at faunalia.it>
> Para: Larry Shaffer <larrys at dakotacarto.com>
> CC: qgis-developer <qgis-developer at lists.osgeo.org>
> Enviado: Viernes 31 de enero de 2014 7:53
> Asunto: Re: [Qgis-developer] Lidar data into QGIS
> Il 30/01/2014 18:41, Larry Shaffer ha scritto:
>>> To revisit your original immediate need, does the output from Howard's
>>> Hexer tool visualize what you are looking for?
>>> https://github.com/hobu/hexer
> Hi Larry,
> we do not have immediate needs, it's a mid-term goal to make LAS data
> available in QGIS.
> Thanks anyway for the suggestion, interesting; probably it would be good
> to check if there is something we can integrate or reuse.
> All the best.
> Paolo Cavallini - www.faunalia.eu
> QGIS & PostGIS courses: http://www.faunalia.eu/training.html
> Qgis-developer mailing list
