[Qgis-developer] qgis compile with xcode 5.1.1 (qgis2.5.0.xcodeproj can not be opened Because the project file cannot be parsed.)
William Kyngesburye woklist at kyngchaos.com
Wed Jul 23 06:52:21 PDT 2014
I didn't have much luck with generated Xcode project files way back before I overhauled the cmake configuration.  You're better off making it by hand (I did that for a while, but it was a pain to maintain).  Or just use the build instructions and do it all in the Terminal.
Cmake has probably improved its xcode generator, but QGIS is a complex project and I still wouldn't trust cmake to get it right.
On Jul 22, 2014, at 10:59 PM, otmane yazidi alaoui <yazidiotmane at gmail.com> wrote:
> 	• Hit the Configure button near the bottom of the window.
> 	• Pick 'XCode' as the generator and choose to use the native compilers.
> 	• Answer Ok when asked if you want to create the build directory.
> 	• Wait for the configure process to finish
> 	• The screen will now have several configuration options on it, which will be red. You don't need to change their value. Just click the Configure button again.
> 	• The options will turn grey, and the Generate button at the bottom will now be enabled. Click Generate.
> 	• The build files will now be generated in the location you picked.
> but the open file create, I get this error:
> Qgis-developer mailing list
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
Earth: "Mostly harmless"
- revised entry in the HitchHiker's Guide to the Galaxy
