[Qgis-developer] qgis compile with xcode 5.1.1 (qgis2.5.0.xcodeproj can not be opened Because the project file cannot be parsed.)
Larry Shaffer
larrys at dakotacarto.com
Wed Jul 23 06:55:25 PDT 2014
If you are feeling adventurous, you can try a new methodology for setting
up a development environment on Mac [0]. It utilizes the Homebrew package
manager, and requires no manual compiling, and many pre-compiled binaries
(if everything goes smoothly).
Please post any issues to the tap's tracker [1].
[0]
https://github.com/OSGeo/homebrew-osgeo4mac/wiki/Developing-on-QGIS-using-OSGeo4Mac
[1] https://github.com/OSGeo/homebrew-osgeo4mac/issues
Regards,
Larry Shaffer
Dakota Cartography
Black Hills, South Dakota
On Tue, Jul 22, 2014 at 9:59 PM, otmane yazidi alaoui <
yazidiotmane at gmail.com> wrote:
> 1. Hit the *Configure* button near the bottom of the window.
> 2. Pick 'XCode' as the generator and choose to use the native
> compilers.
> 3. Answer *Ok* when asked if you want to create the build directory.
> 4. Wait for the configure process to finish
> 5. The screen will now have several configuration options on it, which
> will be red. You don't need to change their value. Just click the
> *Configure* button again.
> 6. The options will turn grey, and the *Generate* button at the bottom
> will now be enabled. Click *Generate*.
> 7. The build files will now be generated in the location you picked.
> but the open file create, I get this error:
> parsed.
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140723/e4b14f7b/attachment.html>
