[Qgis-developer] Legend refactoring branch merged
Martin Dobias
wonder.sk at gmail.com
Mon Jun 2 08:36:41 PDT 2014
Hi Hugo
On Mon, Jun 2, 2014 at 10:13 PM, Hugo Mercier <hugo.mercier at oslandia.com> wrote:
> Hi Martin,
> Le 21/05/2014 19:11, Martin Dobias a écrit :
>> Hi everyone
>> I have just merged the first part of the legend refactoring work to
>> master [1]. It does not really bring any new features for the end
>> user, the changes are mainly under the hood. Things should ideally
>> work as before, if not then probably it is a bug.
> Thanks for all the great work.
> When adding a new layer, the behaviour used to be that the new layer was
> placed on top of the active layer. It is not the case anymore if I am
> correct.
Works for me exactly as expected - new layer is placed on top of the
active layer.
> When passing a list of layers in a certain order to
> QgsMapCanvas::setLayerSet(), the obtained order seems random (from
> Python). Is it wanted ? (not sure if it was already the case before your
> changes)
I am not sure if I understand what you mean.... order obtained from
where? from map canvas?
> Is there a way to modify the order of layers in the legend (and in the
> rendering) via the Python API ?
Not yet, I am about to add python bindings very soon (tomorrow probably).
Regards
Martin
