[Qgis-developer] Opinion on plugin named prepair (and possible likes)
Ken Arroyo Ohori G.A.K.ArroyoOhori at tudelft.nl
Fri Jun 6 11:12:43 PDT 2014
Dear Larry,
The prepair Mac binary was made by linking to static versions of CGAL, boost, GMP, GMPXX, MPFI and MPFR, and only linking dynamically to Kyngchaos’ GDAL framework. The idea was that if people use Kyngchaos’ QGIS package, they already have his GDAL framework since it is a requirement.
For Homebrew, I think the solution in your formula is the right way to go. Linking statically to the other libraries wouldn’t make sense.
All the best,
Ken
> From: Larry Shaffer <larrys at dakotacarto.com>
> Date: 6 juni 2014 17:30:53 CEST
> To: h.ledoux at tudelft.nl
> Cc: QGIS Developer List <qgis-developer at lists.osgeo.org>
> Subject: Re: [Qgis-developer] Opinion on plugin named prepair (and possible likes)
> Hi Hugo,
> About a month ago, I created a formula for prepair in the OSGeo4Mac Homebrew tap [0,1].
> I would appreciate it if you would review it, and possibly do any pull requests for changes you feel are appropriate. Specifically, what options you used to create the new Mac binary for your plugin, where it is only linked to GDAL's lib (I haven't looked into it yet).
> On Fri, Jun 6, 2014 at 7:29 AM, Hugo Ledoux <h.ledoux at tudelft.nl> wrote:
> On Fri, Jun 6, 2014 at 3:11 PM,  <qgis-developer-request at lists.osgeo.org> wrote:
> > I also agree with Nathan: would you like to cooperate with QGIS core team, and
> > incorporate your logic, possibly your code, in QGIS itself?
> > All the best.
> Yes we’re willing to do that. It should be stressed out here that we
> use CGAL (www.cgal.org, which is GPL) and its depends (GMP, MPFR,
> Boost).
> Boost is a very large extra dependency, indeed.
> [0] https://github.com/OSGeo/homebrew-osgeo4mac
> [1] https://github.com/OSGeo/homebrew-osgeo4mac/blob/master/Formula/prepair.rb
> Regards,
> Larry Shaffer
> Dakota Cartography
> Black Hills, South Dakota
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140606/2dda5cb9/attachment.html>
