[Qgis-developer] Value Tool disabled when another tool selected
Jamie Adams jaadfoo at gmail.com
Fri Jun 6 13:58:18 PDT 2014
I just updated - it's now working as expected.  Thanks for the quick fix.
On Fri, Jun 6, 2014 at 1:39 PM, Etienne Tourigny <etourigny.dev at gmail.com>
wrote:
> I actually fixed this last month, and forgot to upload a new version. I've
> been busy finishing my PhD the last few months which explains this!
> I have just uploaded version 0.8.5 to the plugin repos.
> Etienne
> On Fri, Jun 6, 2014 at 5:15 PM, Jamie Adams <jaadfoo at gmail.com> wrote:
>> Ok, thanks.  I filed a bug for this: http://hub.qgis.org/issues/10490
>> On Fri, Jun 6, 2014 at 11:27 AM, Etienne Tourigny <
>> etourigny.dev at gmail.com> wrote:
>>> I have implemented this to be able to identify on a mouse click instead
>>> of whenever you move the mouse (this is an optional behaviour). This
>>> requires the tool being a map tool, and you cannot have more than one
>>> active map tool.
>>> However, when the mouse click option is not enabled, it is NOT used as a
>>> map tool therefore it should not be deactivate when another map tool is
>>> used.
>>> If you uncheck that option (first in the Options dialog) and you still
>>> get that behavior it is a bug, and you should file a bug report (I can't
>>> reproduce with qgis 2.2).
>>> Default is this option turned off, so if you didn't change the option
>>> yourself that would be a bug also.
>>> Etienne
>>>  On Fri, Jun 6, 2014 at 1:47 PM, Jamie Adams <jaadfoo at gmail.com> wrote:
>>>>  I've noticed the new version of the Value Tool plugin (0.8.4)
>>>> automatically have the "Enable" button unchecked when another tool is
>>>> selected.  What is the rationale for this change?  I draw polygons on top
>>>> of raster files to be used during post processing and need the raster
>>>> values for reference.  This change breaks that functionality.
>>>> I'm running QGIS 2.2 on Ubuntu 14.04.
>>>> Thanks,
>>>> Jamie
>>>> _______________________________________________
>>>> Qgis-developer mailing list
>>>> Qgis-developer at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140606/f46ba6ec/attachment.html>
