[Qgis-developer] Value Tool disabled when another tool selected
Etienne Tourigny
etourigny.dev at gmail.com
Fri Jun 6 13:39:50 PDT 2014
I actually fixed this last month, and forgot to upload a new version. I've
been busy finishing my PhD the last few months which explains this!
I have just uploaded version 0.8.5 to the plugin repos.
Etienne
On Fri, Jun 6, 2014 at 5:15 PM, Jamie Adams <jaadfoo at gmail.com> wrote:
> Ok, thanks. I filed a bug for this: http://hub.qgis.org/issues/10490
> On Fri, Jun 6, 2014 at 11:27 AM, Etienne Tourigny <etourigny.dev at gmail.com
> > wrote:
>> I have implemented this to be able to identify on a mouse click instead
>> of whenever you move the mouse (this is an optional behaviour). This
>> requires the tool being a map tool, and you cannot have more than one
>> active map tool.
>> However, when the mouse click option is not enabled, it is NOT used as a
>> map tool therefore it should not be deactivate when another map tool is
>> used.
>> If you uncheck that option (first in the Options dialog) and you still
>> get that behavior it is a bug, and you should file a bug report (I can't
>> reproduce with qgis 2.2).
>> Default is this option turned off, so if you didn't change the option
>> yourself that would be a bug also.
>> Etienne
>> On Fri, Jun 6, 2014 at 1:47 PM, Jamie Adams <jaadfoo at gmail.com> wrote:
>>> I've noticed the new version of the Value Tool plugin (0.8.4)
>>> automatically have the "Enable" button unchecked when another tool is
>>> selected. What is the rationale for this change? I draw polygons on top
>>> of raster files to be used during post processing and need the raster
>>> values for reference. This change breaks that functionality.
>>> I'm running QGIS 2.2 on Ubuntu 14.04.
>>> Thanks,
>>> Jamie
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140606/83a2be15/attachment.html>
