[Qgis-developer] Value Tool disabled when another tool selected
Jamie Adams
jaadfoo at gmail.com
Fri Jun 6 13:15:05 PDT 2014
Ok, thanks. I filed a bug for this: http://hub.qgis.org/issues/10490
On Fri, Jun 6, 2014 at 11:27 AM, Etienne Tourigny <etourigny.dev at gmail.com>
wrote:
> I have implemented this to be able to identify on a mouse click instead of
> whenever you move the mouse (this is an optional behaviour). This requires
> the tool being a map tool, and you cannot have more than one active map
> tool.
> However, when the mouse click option is not enabled, it is NOT used as a
> map tool therefore it should not be deactivate when another map tool is
> used.
> If you uncheck that option (first in the Options dialog) and you still get
> that behavior it is a bug, and you should file a bug report (I can't
> reproduce with qgis 2.2).
> Default is this option turned off, so if you didn't change the option
> yourself that would be a bug also.
> Etienne
> On Fri, Jun 6, 2014 at 1:47 PM, Jamie Adams <jaadfoo at gmail.com> wrote:
>> I've noticed the new version of the Value Tool plugin (0.8.4)
>> automatically have the "Enable" button unchecked when another tool is
>> selected. What is the rationale for this change? I draw polygons on top
>> of raster files to be used during post processing and need the raster
>> values for reference. This change breaks that functionality.
>> I'm running QGIS 2.2 on Ubuntu 14.04.
>> Thanks,
>> Jamie
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140606/ec51f4e9/attachment.html>
