[Qgis-developer] QGIS Server: using same layer name in different projects
Luca Manganelli
luca76 at gmail.com
Thu Jun 19 00:59:43 PDT 2014
I discovered that if you use QGIS Server along two different project
that share the same layer name.
I.e.:
first project:
"roads" layer name ---> I use the postgis table name "roads",
filtered by highways
second project:
"roads" layer name ---> I use the postgis table name "roads", with
no filter (all road types)
If you first visit with Qgis Web Client the first project, then the
second you see only highways.
I think that this is due to QGIS Server WMS caching, or am I wrong?
