[Qgis-developer] Processing: module duplications
Alex Mandel
tech_dev at wildintellect.com
Tue Jun 24 01:10:28 PDT 2014
I disagree, the Vector and Raster menus are the Basic algorithms.
Opening Processing is the Normal+Experimental as Paolo described.
Moving everything to Processing just makes it harder to find the simple
stuff. Another major GIS project many of us know took this approach and
it's extremely annoying to sift through 300 methods when you just want a
Clip. 1. Finding and remembering where the tool you want becomes harder,
2. Searching gets challenging with many similarly named things - wait is
that the raster clip or the vector clip?
Not saying a level filter in the Processing box won't be good, just
don't eliminate the simple menus even if it is a duplicate.
Thanks,
Alex
On 06/23/2014 10:06 AM, G. Allegri wrote:
> I've given a look to the list of Processing QGIS geoalgorithms and I've
> seen that all the tools from fTools seem to be there. I remembered that
> someone was missing, but it seems not to be true anymore. I wonder if it
> wouldn't be the case to drop fTools algorithms from Vector menu. It would
> help in avoiding confusion, imho.
> giovanni
> 2014-06-23 18:50 GMT+02:00 G. Allegri <giohappy at gmail.com>:
>> Hi Paolo,
>> I agree with you, a cleaner organization of Processing tools is advisable
>> to reduce the confusion in users.
>> It's rather difficult to teach them in a clear way too! :)
>> IMHO this reorganization should consider also the integration of other
>> sparse analysis/processing tools, like the ones under the Vector menu. I
>> know it depends on their implemention (and its feasibility in the present
>> Processing model), but it's one of the major sources of confusions or
>> users. A typical question: why we have the Processing toolbox and a Vector
>> menu, where some tools overlap, while other are only available under Vector
>> menu, and so not usable inside a Processing model/workflow?
>> I hope we will find time (=money) to close this gap and, hopefully, have
>> most of the analysis tools under the same structure. Well... all but the
>> C++ ones :(
>> giovanni
>> 2014-06-23 18:42 GMT+02:00 Paolo Cavallini <cavallini at faunalia.it>:
>> Hi all.
>>> We are thinking about the future of Processing framework. The duplication
>>> shown among
>>> modules is certainly a good thing, as it allows richer analyses and more
>>> control and
>>> verification, but can be intimidating even for skilled GIS users.
>>> We have been discussed this before, but I came up with the conclusion
>>> that a
>>> reasonable approach would be to have three levels:
>>> * basic - only one choice, no overly complex modules
>>> * normal - all well tested modules, minimizing duplication
>>> * experimental - out in the wild, all modules.
>>> This would improve the user experience, and would require less
>>> maintenance by core devs.
>>> Of course the selection of the modules for the second category is rather
>>> complex, and
>>> would require much thinking.
>>> Opinions?
>>> All the best.
>>> Paolo Cavallini - www.faunalia.eu
>>> Corsi QGIS e PostGIS: http://www.faunalia.eu/training.html
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
