[Qgis-developer] Display a Photo stored in varbinary from MSSQL Server 2008R2
DewaldvS
dewaldvanstaden at yahoo.com
Tue Jun 24 02:27:30 PDT 2014
DewaldvS wrote
> Good day.
> I am new to QGis.
> Environment used:
> 1. QGis 2.2.0
> 2. MS SQL Server 2008 R2
> Scenario:
> I have a thumbnail stored in a varbinary(max) column, that the user needs
> to see.
> For example: When the user clicks on a water source, they would like to
> see the different images that are linked to that water source and the
> relative information that goes with that selected water source.
> I can get the information to display, but for some reason even when
> changing the Edit widget (@Properties/Fields dialog) to Photo and
> assigning the height and width to the image box still no image is shown.
> I know that the encoding of the varbinary(max) column is correct, because
> if I connect a different viewer to the table, the column is interpreted
> correctly.
> Could you please assist me with this matter?
> Thank you for your time
Any possible thoughts/solutions to my question?
View this message in context: http://osgeo-org.1560.x6.nabble.com/Display-a-Photo-stored-in-varbinary-from-MSSQL-Server-2008R2-tp5146477p5147510.html
Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
