[Qgis-developer] qgis-server and troubles using jpeg as output format
Andrea Peri aperi2007 at gmail.com
Tue Jun 24 06:26:40 PDT 2014
I do some tests.
Using a shell environment to see any error returned.
I see using the
"FORMAT=image/png"
 the image is correctly returned.
Instead using the
"FORMAT=image/jpeg"
the image is not returned.
But no crash at all.
Simply the qgis-server request will end returning nothing.
Also using a debug session no error reported.
Only apparently return nothing.
A.
2014-06-24 14:31 GMT+02:00 Andrea Peri <aperi2007 at gmail.com>:
> Hi,
> I'm having some trouble with qgis-server and the output in jpeg format.
> The request getmap using the jpeg format as not response at all.
> I try on two distinct debian machine but the result is the same.
> So I guess the most probable theory is the lack of a library or a
> library too early on Debian stable distro'.
> So I like to know what is the used jpeg library and if there is a
> minimal version for the jpeg library used.
> Thx
> Andrea Peri
> qwerty àèìòù
Andrea Peri
qwerty àèìòù
