[Qgis-developer] Project migrations
kimaidou
kimaidou at gmail.com
Thu Jun 26 01:27:41 PDT 2014
I agree this is far from the best solution. I was proposing in case we have
no time to debug this before the release. Better do it in core in the
QgsProjectFileTransform class.
Regards
Michael
2014-06-26 9:52 GMT+02:00 Martin Dobias <wonder.sk at gmail.com>:
> On Thu, Jun 26, 2014 at 2:22 PM, kimaidou <kimaidou at gmail.com> wrote:
> > +1 It is not a critical bug in terms of code, but for users with complex
> > projects (many projects, many layers, etc.), this prevent them from
> > migrating to new versions because they cannot always find time to correct
> > everything by hand.
> > We could create a "quick and dirty" processing script "Fix border for old
> > projects" which will use some regex magic to read a project file, search
> and
> > replace, and then write a new version ? If someone knowing well the
> problem
> > could provide a diff between the 2 QML (or <maplayer> items), I think I
> can
> > find time to try to help a bit here
> The processing scripts are not a real solution - they may help few
> people that are aware of the problem and of the script - but the
> majority will still run into the trouble. These things should be
> solved by implementing project transforms in the QGIS libraries. The
> mechanism is there already, just the transformation code for this
> particular case is missing.
> Regadrs
> Martin
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140626/0d434222/attachment.html>
