[Qgis-developer] What about a qgis project add function ?
Andre Joost
andre+joost at nurfuerspam.de
Sun Mar 2 00:35:02 PST 2014
Am 02.03.2014 07:21, schrieb Geo DrinX:
> Hi Regis,
> do you intend this :
> "ImportProject is a plugin that lets you load layers from another project
> file. Just select a project (.qgs) file,
> check off the layers you wish to load, and it will include them in your
> current project with all styling.
> Works with vector, raster, database and web service layers."
Unfortunately, it throws error messages for me:
> Traceback (most recent call last):
> File
"C:/Users/Joost/.qgis2/python/plugins\importLayersFromProject\main.py",
line 65, in run
> window.populateTable(filePath)
> File
"C:/Users/Joost/.qgis2/python/plugins\importLayersFromProject\LayerDialog.py",
line 31, in populateTable
> info = getMapInfo(maps.item(i))
> File
line 85, in getMapInfo
> return
{'name':name,'ds':ds,'mtype':mtype,'geom':geom,'provider':provider}
> UnboundLocalError: local variable 'geom' referenced before assignment
Adding a project with absolute paths and without tile layers works, so I
suggest to catch these cases before the error message occurs.
The plugin Homepage is a little odd:
<http://plugins.qgis.org/plugins/importLayersFromProject/>
calls this bug tracker page:
<http://hub.qgis.org/projects/ImportLayersFromProject>
which does not exist. From the plugin page inside QGIS, these pages are
not accessible either. I think you messed up with "import" and "Import".
Greetings,
André Joost
