[Qgis-developer] QGIS web client not displaying full WMS extent
    Andreas Neumann
    a.neumann at carto.net
    Tue Nov  4 07:14:08 PST 2014
Hi Stefan,
I am a bit confused. As far as I can tell there is no web client
involved - only some other WMS server and some other Web-GIS - right?
So - the actual problem is that QGIS desktop does not show the full
extent of the other WMS server - so purely a "QGIS as a WMS client"
issue - right?
I would double check the projection setting first, to see if WMS server
and WMS client are on the same projection. That would be my first check.
Andreas
On 04.11.2014 14:50, Blumentrath, Stefan wrote:
> Hi,
> I am having some trouble with properly displaying a WMS in QGIS 2.5:
> The web-client
> (http://kart.fiskeridir.no/default.aspx?gui=1&lang=1 (activate e.g.
> first layer in the "Fiskeriaktivitet"-tab) for the WMS I use displays
> a much wider data extent than the WMS in QGIS
> (http://kart.fiskeridir.no/wms.aspx? , here one may have to set tile
> size (something like 1000x1000) and choose png format in order to make
> it visible). In QGIS the WMS seems to be clipped in N,S,E, and W,
> while another proprietary GIS displays the WMS correctly (like the
> web-client)...
> Any idea what the problem could be here?
> Is it a user issue, a server issue or is it a web-client issue and
> probably related to (or a variant of):
> https://hub.qgis.org/issues/10634
> I was using QGIS 2.5 master (d833c22) through OSGeo4W.
> Thanks in advance for helping.
> Cheers
> Stefan
> P.S.: I had this posting already on the user-mailinglist, but managed
> to send it into another existing thread (and got no response), so I
> hope you do not mind that I re-send it to the devs-list...
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20141104/ab186eb5/attachment-0001.html>
