[Qgis-developer] Virtual Fields - Allow adding fields out of edit mode
    Bernhard Ströbl
    bernhard.stroebl at jena.de
    Tue Oct 14 00:44:13 PDT 2014
Hi Matthias,
Am 14.10.2014 09:15, schrieb Matthias Kuhn:
> Hi Bernhard,
> On 14.10.2014 07:36, Bernhard Ströbl wrote:
>> Hi Matthias,
>> thank you for your work!
> Thank you for the review
>> However I have some small issues and a bug [1]
>> - I do not see any notification when not in edit mode but my action
>> requires edit mode (edit mode is turned on, though, when clicking OK)
> That was just fixed
>> - shouldn't "create virtual field" be the default when layer is not in
>> edit mode?
> I think it's more predictable (and therefore increases usability) for
> users if it's either always on or always off by default. Don't you think?
Ok, agreed, so I opt for "always on" because it will always work
>> - could the check box "create virtual field" be placed to the right of
>> "create a new field"?
> "Create a new field" is a group box.
> Would you create another group box with all field type widgets?
No of course not :-) I was not aware of the group box. I just had the
impression it should be there, so moving it on top seems adequate.
I doubt
> it's easy to place it in the group box header as well. But I could
> easily take it to the top, just below the header.
> Best regards
> Matthias
thanks
Bernhard
__________ Information from ESET Mail Security, version of virus signature database 10558 (20141014) __________
The message was checked by ESET Mail Security.
http://www.eset.com
