[Qgis-developer] error when saving modified features via wfs-t/qgis server
    René-Luc Dhont
    rldhont at gmail.com
    Mon Oct 27 01:46:54 PDT 2014
Hi Giovanni,
If tinyows and QGIS-Server can't save feature through WFS-T, it's
probably an issue in the QGIS WFS Client, isn't it ?
Regards,
René-Luc
Le 24/10/2014 18:43, Giovanni Manghi a écrit :
>> Hi all,
>> I'm noticing the following when editing features via wfs-t (with qgis
>> as client and as server): if the modified feature has a lot of nodes
>> then saving give this error
>> Errors: ERROR: 1 geometries not changed.
>> Provider errors:
>> empty response
>> if I simplify/generalize the feature then (at some point after
>> generalizing quite a lot) modifying/saving via wfs-t works ok.
>> Adding/deleting features operations are not affected.
>> I tested both qgis 2.4 and master both as client and server using both
>> shapes and postgis as source data.
>> Is this a known limitation?
> I'm also having troubles saving on a tinyows server
> Could not commit changes to layer tows:dist2_single2
> Provider errors:
> WFS exception report (code=InvalidParameterValue text=XML request isn't valid)
> cheers
