[Qgis-developer] Memory Layers - some proposals
Mathieu Pellerin nirvn.asia at gmail.com
Wed Sep 24 23:27:36 PDT 2014
Possibly although that'd clutter that space. Renaming Memory Layers to
Temporary Layers would also give a good clue.
That said, I must say I quite enjoy using the memory layer saver, I'd be
sad to see this function not making it into core.
Martin raised an important issue re format. What about saving memory layer
data as GeoJSON within the qgis project file? That's a solution that is
compatible with the project file's xml format.
Thoughts on that?
On 25 Sep 2014 13:03, "Nathan Woodrow" <madmanwoo at gmail.com> wrote:
> What about a icon in the legend to note that it it's not going to be saved?
> - Nathan
> On Thu, Sep 25, 2014 at 3:57 PM, Mathieu Pellerin <nirvn.asia at gmail.com>
> wrote:
>> Thoughts:
>> - I don't think warning should be occurring when creating a memory layer
>> (that is when pasting as new layer, when adding the result of a processing
>> algorithm as memory layer, or creating a blank memory layer)
>> - I don't think the user should be able to disable the warning message
>> (which imo should be a dialog with saving shortcuts), the resulting data
>> loss is too critical; it's like opening a project with missing layers, qgis
>> doesn't (and shouldn't) allow for this dialog to be skipped
>> - IMO best to have: a/ a message bar when saving project while in an
>> ongoing session, and a missing layer-like warning dialog when closing
>> project
>> On 25 Sep 2014 12:15, "Denis Rouzaud" <denis.rouzaud at gmail.com> wrote:
>>> On 25.09.2014 04:02, Mathieu Pellerin wrote:
>>>    Regarding the saving aspect of it, IMO it needs to be worked out.
>>> I've had a couple of users over here already reporting "data loss" with the
>>> following scenario:
>>>  1. Open his/her project
>>> 2. Copies one polygon from a large dataset and pastes is as a new memory
>>> layer (very useful feature introduced in QGIS 2.x)
>>>  3. Styles the memory layer, and saves the project
>>>  4. The next day, when he/she re-opens the project, the polygon is gone
>>>  Throughout the above mentioned workflow, there was never _any_
>>> indication that the pasted memory layer would not be saved when saving the
>>> project.
>>>  If QGIS further ease access to memory layers via incorporating the new
>>> memory layer function into the core (which I hope its done :) ), and decide
>>> against saving across project session, then there must be a UX to deal with
>>> that, instead of silently killing the data of the memory layer(s). One way
>>> forward would be to have a warning upon closing a project that has
>>> non-saveable memory layers to warn the users. That warning should offer for
>>> users to save the memory layers onto a proper format (possibly like the
>>> missing layer dialog, with a list of all the memory layers and an input to
>>> add the saved file location/name).
>>> I would be in favor of a warning when first create a memory layer. The
>>> warning would say you can't save them except from using a plugin. And,
>>> there would be a checkbox "do not display this warning anymore".
>>>  Math
>>> On Thu, Sep 25, 2014 at 4:07 AM, Martin Dobias <wonder.sk at gmail.com>
>>> wrote:
>>>> Hi Nyall
>>>> On Thu, Sep 25, 2014 at 3:31 AM, Nyall Dawson <nyall.dawson at gmail.com>
>>>> wrote:
>>>> > Hi all,
>>>> > The recent discussion around memory layers in another thread has
>>>> started me
>>>> > thinking about the best way to expose them more readily to users.
>>>> > As such, I've opened a pull request which ports Borys Jurgiel's "New
>>>> Memory
>>>> > Layer" plugin to core (PR #1591). Hopefully this can be merged for
>>>> 2.6. It's
>>>> > more or less a direct port - I've left it without the ability to
>>>> specify
>>>> > fields at creation time as I believe that field creation would
>>>> indicate that
>>>> > we are encouraging users to store real data in these layers, which is
>>>> > something we should avoid.
>>>> Cool - from time to time it is handy to make a memory layer for some
>>>> temporary data and having to use a plugin / python console for the
>>>> creation is suboptimal...
>>>> > What I'm thinking though is that we should rename "memory layers"
>>>> within the
>>>> > UI. The name suggests that they are remembered, and conveys more of a
>>>> > permanent feel.
>>>> > I think that for 2.6 we could rename them to "temporary scratch
>>>> layers", and
>>>> > then for >2.6 (after we port the memory layer saving plugin/decide on
>>>> a
>>>> > suitable format for saving them) drop the " temporary" part of this
>>>> name. So
>>>> > they'll be just "scratch layers".
>>>> I like the name "scratch layer" - and I wouldn't mind having it from
>>>> 2.6 even without the "temporary" part although there is no saving for
>>>> it. (Saving is still a bit controversial for me as we would
>>>> inadvertently create another vector file format - unless we would ask
>>>> user to save the layer data into one of OGR supported formats or
>>>> spatialite DB.)
>>>> Cheers
>>>> Martin
>>>> _______________________________________________
>>>> Qgis-developer mailing list
>>>> Qgis-developer at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Qgis-developer mailing listQgis-developer at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140925/910e17f8/attachment.html>
