[Qgis-developer] Thoughts about multi-type tables in QGIS
Olivier Dalang
olivier.dalang at gmail.com
Thu Apr 2 04:52:13 PDT 2015
In some projects of mine, I work with multiple geometry types in one
postgis table, using a column of type geometry(Geometry,4326).
This is very well supported by postgis.
It is possible to load such a table in QGIS by manually selecting the
geometry type you want to load. This means that to display all the
features, you need to add the table three times, one for each feature type.
This works more or less. There are a few bugs though :
- http://hub.qgis.org/issues/12499 (you can edit other type's node with the
node tool)
- http://hub.qgis.org/issues/12500 (other type's records are shown in the
attribute table)
This also has some limitations. When having such a setup, it's pretty sure
you'll want to have the same edit forms for all the layers. You'll also
probably want the same filter, the same labels, the same actions, etc...
The only thing you'd want to be able to define on a geometry type basis are
the symbol (well, even the classification/colors/etc could be shared) and
the label placement.
For now, you must do all settings three times, because of this bug/feature
request :
- http://hub.qgis.org/issues/12303 (copy/paste style from one geometry type
to another)
As you see, support multiple geometry types in QGIS is not perfect.
Of course it's possible to fix the bugs/pr, and there are some workarounds
(postgis view instead of tables) but maybe it's also worth thinking a bit
more in depth about this.
We could consider point/line/polygons as subcategories/sublayers of a
layer. A shapefile or a mono-typed table would have only one of those
sublayer, but a postgis table could perfectly have the three. Most of the
settings would be defined at the layer level, while only some settings
would be defined at the subcategory level.
This is probably especially relevant when thinking long term (the day we
support 3D, curves, etc...).
What do you think ?
Do you think the relation 1 layer = 1 geometry type will hold ?
I think we inherited this from the old shapefile format, but most data
sources QGIS handles don't have this limitation. I also think it does not
hold with quite a lot of modern GIS uses (especially web related, think of
openstreetmaps for instance).
There's this feature request (6th oldest open issue on the tracker) about
postgis geometry collections : http://hub.qgis.org/issues/167
Best,
Olivier
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150402/3737ed55/attachment-0001.html>
