[Qgis-developer] Thoughts about multi-type tables in QGIS
Denis Rouzaud
denis.rouzaud at gmail.com
Thu Apr 2 05:10:59 PDT 2015
Hi Olivier,
I think you can easily extend your reasoning to the support of multiple
geometry columns in QGIS.
I believe that this would come in QGIS at some point.
If QGIS 3 is getting closer, our company will support this feature.
As you suggest, the layer could have different geometry types and/or
columns. This could be seen as sub-layer level for rendering:
layer > geometry types/columns > symbology rules
I suppose this is quite a big change. Many things depends on the
geometry type in QGIS (like map map tools), and that would represent a
large API break.
But, on my side, I believe it's a logic evolution for QGIS.
Best wishes,
Denis
On 04/02/2015 01:52 PM, Olivier Dalang wrote:
> Hi,
> In some projects of mine, I work with multiple geometry types in one
> postgis table, using a column of type geometry(Geometry,4326).
> This is very well supported by postgis.
> It is possible to load such a table in QGIS by manually selecting the
> geometry type you want to load. This means that to display all the
> features, you need to add the table three times, one for each feature
> type.
> This works more or less. There are a few bugs though :
> - http://hub.qgis.org/issues/12499 (you can edit other type's node
> with the node tool)
> - http://hub.qgis.org/issues/12500 (other type's records are shown in
> the attribute table)
> This also has some limitations. When having such a setup, it's pretty
> sure you'll want to have the same edit forms for all the layers.
> You'll also probably want the same filter, the same labels, the same
> actions, etc...
> The only thing you'd want to be able to define on a geometry type
> basis are the symbol (well, even the classification/colors/etc could
> be shared) and the label placement.
> For now, you must do all settings three times, because of this
> bug/feature request :
> - http://hub.qgis.org/issues/12303 (copy/paste style from one geometry
> type to another)
> As you see, support multiple geometry types in QGIS is not perfect.
> Of course it's possible to fix the bugs/pr, and there are some
> workarounds (postgis view instead of tables) but maybe it's also worth
> thinking a bit more in depth about this.
> We could consider point/line/polygons as subcategories/sublayers of a
> layer. A shapefile or a mono-typed table would have only one of those
> sublayer, but a postgis table could perfectly have the three. Most of
> the settings would be defined at the layer level, while only some
> settings would be defined at the subcategory level.
> This is probably especially relevant when thinking long term (the day
> we support 3D, curves, etc...).
> What do you think ?
> Do you think the relation 1 layer = 1 geometry type will hold ?
> I think we inherited this from the old shapefile format, but most data
> sources QGIS handles don't have this limitation. I also think it does
> not hold with quite a lot of modern GIS uses (especially web related,
> think of openstreetmaps for instance).
> There's this feature request (6th oldest open issue on the tracker)
> about postgis geometry collections : http://hub.qgis.org/issues/167
> Best,
> Olivier
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150402/ab3fbf39/attachment.html>
