[Qgis-developer] Live layer effects bug?
Nyall Dawson nyall.dawson at gmail.com
Fri Apr 10 04:25:16 PDT 2015
On 10 April 2015 at 18:57, Régis Haubourg
<regis.haubourg at eau-adour-garonne.fr> wrote:
> Hi,
> That new addition may be worth opening a unique topic, I'm unsure where to
> post (dev or user's list).
> I'm testing live layer effects and end up with some weird behaviour. I'm not
> sure if this is a bug or if I didn't get the behaviour correctly.
> I try to reproduce Nyall's blog example of a point symbol with a drop shadow
> with a "mirror effect".
> When applying a transform effect with only a rotation, the rotated symbol is
> thrown away from the original symbol. The more I rotated, the farther it
> goes, in the direction I set.
Mind sharing your symbol details? I can't reproduce this here, but
some more info would help.
> Another point, in today's nightly, there is another checkbox "apply effects"
> outside of the layer effects frame. I didn't get any effect from that. Is
> that a bug?
I don't see this checkbox - is it in the effect properties dialog? Or
in the symbol properties dialog?
Nyall
