[Qgis-developer] Finalising the changelog for 2.8
Tim Sutton
tim at kartoza.com
Wed Feb 25 11:52:16 PST 2015
Hi
On Wed, Feb 25, 2015 at 2:14 PM, Sandro Santilli <strk at keybit.net> wrote:
> On Sat, Feb 21, 2015 at 04:47:39PM +0200, Tim Sutton wrote:
> > Hi
> > On Sat, Feb 21, 2015 at 12:07 PM, Sandro Santilli <strk at keybit.net>
> wrote:
> > > On Sat, Feb 21, 2015 at 10:19:09AM +0200, Tim Sutton wrote:
> > > > http://changelog.qgis.org/qgis/version/2.8/
> > > The "Map rotation in canvas" item mentions you need to explicitly
> > > enable it, but I think Jurgen made it enabled by default, is that
> > > not the case anymore ?
> > OK rereading it, the current text is fine - it makes it clear that the
> > feature will not be enabled if you do not check the feature in settings
> and
> > does not relate to whether it is enabled by default or not.
> If I'm coming from 2.6 and take _no_ action (don't go to settings at all),
> do I get map rotation enabled or not ? I think I do.
Correct. I added "(it wil be enabled by default)" as below - to make it
more obvious.
"This release includes preliminary support for rotation in the map canvas.
You need to explicitly enable this in Settings --> Options --> General -->
Experimental canvase rotation support(it will be enabled by default). Note
that you need to restart QGIS before this feature is enabled. We also
recommend that you start a new project for cases where you wish to rotate
the map canvas. Rotation support has been extended into the map composer
too so that it correctly handles labelling and symbology, etc."
I still think we should just remove the option from settings - how many
users to you think will actually go and disable it and on what basis will
they make the decisions to do so? If you dont want rotation simply leave it
on zero in the status bar? Anyway sorry I don't mean to make it sound like
I am on some kind of crusade :-P If you want different wording to the
above, just supply me what you prefer and I will update it ok?
> If I do (enabled by default) then also the NEWS file should be updated
> as it currently says:
> - Rotation of map canvas (disabled by default, activate in settings) is
> now supported.
Ok I will fix that.
Regards
Tim
> --strk;
Tim Sutton
Visit http://kartoza.com to find out about open source:
* Desktop GIS programming services
* Geospatial web development
* GIS Training
* Consulting Services
Skype: timlinux Irc: timlinux on #qgis at freenode.net
Tim is a member of the QGIS Project Steering Committee
Kartoza is a merger between Linfiniti and Afrispatial
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150225/8b640400/attachment-0001.html>
