[Qgis-developer] Finalising the changelog for 2.8
Sandro Santilli strk at keybit.net
Wed Feb 25 11:56:12 PST 2015
On Wed, Feb 25, 2015 at 09:52:16PM +0200, Tim Sutton wrote:
>  "This release includes preliminary support for rotation in the map canvas.
> You need to explicitly enable this in Settings --> Options --> General -->
> Experimental canvase rotation support(it will be enabled by default). Note
> that you need to restart QGIS before this feature is enabled. We also
> recommend that you start a new project for cases where you wish to rotate
> the map canvas. Rotation support has been extended into the map composer
> too so that it correctly handles labelling and symbology, etc."​
> ​I still think we should just remove the option from settings - how many
> users to yo​u think will actually go and disable it and on what basis will
> they make the decisions to do so? If you dont want rotation simply leave it
> on zero in the status bar? Anyway sorry I don't mean to make it sound like
> I am on some kind of crusade :-P If you want different wording to the
> above, just supply me what you prefer and I will update it ok?
Why not just trimming out the whole Settings explanation ?
 Rotation support has been extended into the map composer too so that
I've also removed the "start new project" as I don't understand why
you would recommend that.
--strk;
  ()   Free GIS & Flash consultant/developer
  /\   http://strk.keybit.net/services.html
