[Qgis-developer] Finalising the changelog for 2.8
Tim Sutton
tim at kartoza.com
Wed Feb 25 12:11:47 PST 2015
Hi
On Wed, Feb 25, 2015 at 9:56 PM, Sandro Santilli <strk at keybit.net> wrote:
> On Wed, Feb 25, 2015 at 09:52:16PM +0200, Tim Sutton wrote:
> > "This release includes preliminary support for rotation in the map
> canvas.
> > You need to explicitly enable this in Settings --> Options --> General
> > Experimental canvase rotation support(it will be enabled by default).
> Note
> > that you need to restart QGIS before this feature is enabled. We also
> > recommend that you start a new project for cases where you wish to rotate
> > the map canvas. Rotation support has been extended into the map composer
> > too so that it correctly handles labelling and symbology, etc."
> > I still think we should just remove the option from settings - how many
> > users to you think will actually go and disable it and on what basis
> will
> > they make the decisions to do so? If you dont want rotation simply leave
> it
> > on zero in the status bar? Anyway sorry I don't mean to make it sound
> like
> > I am on some kind of crusade :-P If you want different wording to the
> > above, just supply me what you prefer and I will update it ok?
> Why not just trimming out the whole Settings explanation ?
I updated so it now reads like this:
# <http://changelog.linfiniti.com/qgis/version/2.8/#231> Feature: Map
rotation in canvas, improved rotation in composer
This release includes preliminary support for rotation in the map canvas.
You can rotate the canvas using the new rotation widget in the status bar.
Rotation support has been extended into the map composer too so that it
This feature was funded by: Georepublic Japan <http://georepublic.co.jp/>
This feature was developed by: Faunalia <http://www.faunalia.eu/>
> I've also removed the "start new project" as I don't understand why
> you would recommend that.
I based that on your recommendation on IRC when I mentioned my labels were
not showing when rotating an existing project (created with an older
version of QGIS).
Regards
Tim
> --strk;
> () Free GIS & Flash consultant/developer
> /\ http://strk.keybit.net/services.html
Tim Sutton
Visit http://kartoza.com to find out about open source:
* Desktop GIS programming services
* Geospatial web development
* GIS Training
* Consulting Services
Skype: timlinux Irc: timlinux on #qgis at freenode.net
Tim is a member of the QGIS Project Steering Committee
Kartoza is a merger between Linfiniti and Afrispatial
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150225/052586db/attachment.html>
