[Qgis-developer] Downloading & compiling QGIS - FEEDBACK
Zoltan Szecsei
zoltans at geograph.co.za
Tue Jan 13 07:24:43 PST 2015
OK, using the instructions below, it all went pretty smoothly except for
the few points below.
Mega-thanks to all who contributed to 'Building QGIS from source' document.
As I said below, I was using a fresh install of 64 bit Ubuntu 14.10 Desktop.
Points noted:
* The version levels of some of the build tools & dependencies in my
install were LOWER than required by this 'Building QGIS' document.
* Perhaps notes on how to get newer versions (than those in the 'Main'
repository) of these tools and dependencies would help. I just
ignored these versions, and carried on ahead.
* Add ccache, python-psycopg2 and python-gdal to the list for apt-get
in section 3.3
* In section 3.6 maybe mention the size of the git checkout and how to
minimise it for those who need to.
* In 3.7 mention explicitly that setting CMAKE_INSTALL_PREFIX is in
the ccmake panel and not as an environment variable :-)
I missed that finer point of this and had to sudo make install - and
then qgis wouldn't run, so I deleted everything in my 'build-master'
and then woke up as to where to set the ${HOME}/apps pointer.
* I ran make & make install as root even though I probably need not have.
* You need to set LD_LIBRARY_PATH to ${HOME}/apps/lib before your
compiled qgis will run.
Hope these findings helps someone.
Regards,
Zoltan
On 2015/01/13 10:44, Nathan Woodrow wrote:
> Zoltan,
> Jump on IRC is normally a good way if you have trouble with building.
> Some of us normally hang around there, or of course you can still
> email the mailing list.
> - Nathan
> On Tue Jan 13 2015 at 18:40:15 Zoltan Szecsei <zoltans at geograph.co.za
> <mailto:zoltans at geograph.co.za>> wrote:
> Hi Matthias
> Thanks for the confirmation.
> I'm just "feeling around" at the moment - and not worried about
> the download size.
> Are the instructions I am following still "current"?
> If I find stuff that I feel maybe missing (ie: things don't go
> according to my expectations from the instructions), is there
> anyone particular I should notify?
> Cheers for now,
> Zoltan (The emigrant one :-) )
> On 2015/01/13 10:33, Matthias Kuhn wrote:
>> Hi Zoltan,
>> That is correct.
>> It is not compressed to 44 objects. It is just compressing (packing) 44
>> objects it has not compressed yet.
>> But git downloads the whole history for you since the very first version
>> of QGIS anyway. That is fine if you are going to develop and want to
>> keep track of what has been done when etc.
>> If you are worried about the download size, you can either use --depth 1
>> when cloning
>> http://gistflow.com/posts/430-git-clone-without-history
>> or just download the zip file of the branch you are interested on the
>> github project page.
>> Regards,
>> Matthias
>> On 01/13/2015 08:43 AM, Zoltan Szecsei wrote:
>>> Hi,
>>> My platform is a "fresh" 64 bit Ubuntu 14.10 desktop install.
>>> I am following these instructions:
>>> http://htmlpreview.github.io/?https://raw.github.com/qgis/QGIS/master/doc/INSTALL.html
>>> Using anonymous checkout, I get told that there are 271040 objects.
>>> This is then compressed to 44 objects
>>> Download begins, but is tracking the 271040 objects instead of the "44".
>>> Is this correct or should it be downloading what I assume to be the
>>> 271040 objects that were compressed into 44 objects?
>>> Regards & TIA,
>>> Zoltan
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Zoltan Szecsei PrGISc [PGP0031]
> Geograph (Pty) Ltd.
> GIS and Photogrammetric Services
> P.O. Box 7, Muizenberg 7950, South Africa.
> Mobile: +27-83-6004028
> Fax: +27-86-6115323www.geograph.co.za <http://www.geograph.co.za>
Geograph (Pty) Ltd.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150113/bc8b7daf/attachment.html>
