[Qgis-developer] Exact print composing
Andreas Neumann
a.neumann at carto.net
Tue Jan 27 06:16:14 PST 2015
Hi Zoltan,
Every object in the print composer can be positioned/scaled with exact
numbers - have a look at the "Position and Size" group of every items
properties. This has been around since ages (at least since version 1.7).
Alternatively/in addition you can also use snappable grids and guidelines.
Hope this helps?
Andreas
On 27.01.2015 15:10, Zoltan Szecsei wrote:
> Hi,
> Is there a way to set exact print composer sizes and map positions?
> I have set a composer canvas size of 460mm by 275mm, and an area of
> interest (made up of one cropped raster and 12 cropped vector maps)
> that is exactly that size, at 1:500 scale.
> Adding this to print composer canvas using a mouse is not exactly
> accurate. I've searched plugins, but noticed nothing useful.
> Does print composer by any chance create a text file that I can hack
> to achieve this?
> Regards,
> Zoltan
