[Qgis-developer] QWC wsgi search
    Andreas Neumann
    a.neumann at carto.net
    Mon Jun 15 11:33:28 PDT 2015
Hi Marc,
Here is a wsgi search query from our server:
http://webgis.uster.ch/wsgi/search.wsgi?searchtables=&query=Werriker&cb=stcCallback1005
Note that there are builtin searchtables that are always used (things
like addresses, parcel numbers, building assurance numbers, geographic
names, etc.) - you can add additional searchtables e.g. for waste-water
pipes, etc.
The double query parameter is a mistake and stems from the fact that it
is by mistake also specified in GlobalOptions.js - look for a line with
Konsole output
varsearchBoxQueryURL = "/wsgi/search.wsgi?";
and remove the extra query parameter. But it is not a big deal, the
second parameter just replaces the empty one.
Other than that you must check the database permissions and if the login
parameters are correct.
In the file "search.js" you have to add the default searchtables array,
if you did not specify one in the URL - something like:
Konsole output
  searchtables =
['surveydata.searchtable_addresses','gisdata.searchtable_geographicnames'];
So please double check that your searchtables can be accessed with the
permissions of the web server user, if the login data is correct and if
the searchtables are specified and contain a valid structure.
Hope this helps,
Andreas
On 15.06.2015 17:46, Marc B wrote:
> Hello List,
> I am trying to connect the WSGI-Search to my PostGIS-Database.
> Unfortunately I am reatively new to python and I dont really understand
> which changes in the search.wsgi/qwc_connect.py I have to make.
> I've created a DB-table like the one from the github instructions.
> I've changed the DB_CONN_STRING in qwc_connect.py.
> Some of my Questions are
> 1. Is there a way to easily test my DB-Connection in qwc_connect?
> 2. The generated URL with parameters is not how ist supposed to be:
>     https://my-page.de/wsgi/search.wsgi?query=&searchtables=&query=wo&cb=stcCallback1001
>     - Why are there 2 'query'-params, an empty and a correct one?
>     - the searchtables-parameter has no value, whether I put in a
>       tablename in the search.wsgi or not ( searchtables =
>       ['searchtable']; # enter your default searchtable(s) here ). Where
>       does this parameter come from? What am i doing wrong?
> If I paste the url in the url bar of chrome it says "error: no search
> table". When I put a searchtable-value in the url i get a blank page.
> It never says 'error: could not execute query'. So I guess, it doesnt
> even get that far.
> Thank you
> Marc
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150615/52551e19/attachment.html>
