[Qgis-developer] Temporal data (was QGIS GRASS Plugin Upgrade Crowdfunding)
Saber Razmjooei
saber.razmjooei at lutraconsulting.co.uk
Mon Mar 30 04:37:07 PDT 2015
Hi all,
If the long term aspiration of having support for temporal data is to
support NetCDF, HDF, GRIB, etc similar to:
http://blogs.esri.com/esri/apl/2015/03/11/dimension-explorer/
then probably we need to have more to it.
Martin has done a major update of the crayfish plugin which now supports
xdmf (a variation of HDF5) and soon we are looking to add animation feature
and more file support:
https://github.com/lutraconsulting/qgis-crayfish-plugin
Cheers,
Saber
-----Original Message-----
[mailto:qgis-developer-bounces at lists.osgeo.org] On Behalf Of Matthias Kuhn
Sent: 30 March 2015 10:31
To: Nyall Dawson
Cc: qgis-developer; grass-dev at lists.osgeo.org
Subject: Re: [Qgis-developer] Temporal data (was QGIS GRASS Plugin Upgrade
Crowdfunding)
Hi
I think the very first step in this should be to add proper date (time)
support.
I don't know the state and requirements for raster layers, but for vector
layers I think right now time is converted with the edit types just for
visualization but internally it is passed around as string. It would be nice
to handle them as QDate(Time) internally.
For time-aware databases (postgres...) this should be straightforward.
For others (like shapefile?) we probably need to manage the datatype on the
project level but conversion should IMHO happen low-level directly in the
provider code so things like timezone handling and whatever else needs to be
done can happen exactly once when the data is read from the datasource or
saved to the datasource.
Filtering (from date ... to date ) should best be done on the
QgsFeatureRequest level (setFilterExpression should already be ready I
guess)
Best,
Matthias
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-developer
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed.
If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the
individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately
by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. If you are not the intended recipient you are notified
that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
Whilst reasonable care has been taken to avoid virus transmission, no responsibility for viruses is taken and it is your responsibility to carry out
such checks as you feel appropriate.
If this email contains a quote or offer to sell products, carry out work or perform services then our standard terms and conditions (which can be found at http://www.lutraconsulting.co.uk/downloads/Lutra%20Consulting%20Standard%20Terms%20and%20Conditions.pdf shall apply unless explicitly stated otherwise.
Saber Razmjooei and Peter Wells trading as Lutra Consulting.
