[Qgis-developer] Problem with the MySQL/GDAL implementation in QGIS
Pavol Hnila pavol.hnila at fu-berlin.de
Fri May 8 06:09:24 PDT 2015
Even is right again. I have made tests with QGIS 2.8.1 and PostGIS and
have experienced the same problem with opening and closing of OGR
datasources as with MySQL. And I need to add that it applies also to a
single table in a dabase.
Is there anybody on the list who is regularly using QGIS >2.0 with MySQL
or PostGIS spatial layers and who does not have this issue? (I just try
to understand, whether it is a general problem or whether it is specific
to my data or settings...)
Best,
Pavol
On 07.05.2015 15:09, Even Rouault wrote:
> A few precisions:
>> My current conclusions are:
>> 1) the problem is likely in the implementation of MySQL/GDAL driver
>> since QGIS 2.0
> This should rather read : "The problem is likely the implementation of OGR
> datasource management in QGIS since QGIS XXXX"
