[Qgis-developer] [Linux Mint] QGIS 2.8.1. stop work when upgrading to GDAL 11.1.2
Sebastiaan Couwenberg sebastic at xs4all.nl
Sat May 9 06:46:44 PDT 2015
On 05/09/2015 03:17 PM, João Gaspar wrote:
> 2015-05-09 13:41 GMT+01:00 Sebastiaan Couwenberg <sebastic at xs4all.nl>:
>> On 05/09/2015 02:16 PM, João Gaspar wrote:
>>> i upgrade the gdal1.11.1 to gdal1.11.2 in synaptic repository and the
>>> QGIS 2.8.1 don't work anymore.
>> Every time a new version of gdal is uploaded, all its reverse
>> dependencies that rely on its C++ symbols need to be rebuilt.
>> See the discussion on the Ubuntu list:
>> http://lists.osgeo.org/pipermail/ubuntu/2015-May/001236.html
>> And the related discussion in the Debian gdal transition bugreport:
>> https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=756867#30
> thanks for your quick answer. I read the links but how can i use this
> in terms of terminal?
You can't do much except rebuild the qgis package with the new gdal
1.11.2 package to fix the dependency issue.
The qgis rebuilds in the UbuntuGIS PPA failed [1] due an issue with the
grass << 7 dependency. Once that's resolved qgis should be installable
from the UbuntuGIS PPA again.
[1]
https://launchpad.net/~ubuntugis/+archive/ubuntu/ubuntugis-unstable/+build/7402276
> I read this part:
> - add Provides: libgdal.so.1-${version} to libgdal1h (${version} being
>   1.10.1 or 1.11.0)
> - adjust libgdal1h.symbols.* to generate a dep on
>   libgdal.so.1-${version} for all c++ symbols
These changes where implemented in gdal (1.11.0+dfsg1-1~exp5), and for
subsequent upstream releases the virtual package dependency is bumped to
require the upstream same version. See for example:
http://anonscm.debian.org/cgit/pkg-grass/gdal.git/commit/?h=experimental&id=eb297295aee168c6d8fb0ac741206541ec249cdf
I plan to restart the GDAL 1.11.2 transition in Debian unstable after
the PROJ 4.9.1 transition is complete and the rebuilt reverse
dependencies have migrated to testing.
Thanks to the great work by Johan Van de Wauw GDAL 1.11.2 is already
included in Ubuntu since vivid.
Kind Regards,
Bas
 GPG Key ID: 4096R/6750F10AE88D4AF1
Fingerprint: 8182 DE41 7056 408D 6146  50D1 6750 F10A E88D 4AF1
