[Qgis-developer] Qt4->Qt5 timeline: Qt4's status and Qt4's webkit removal in Stretch
Tim Sutton tim at kartoza.com
Sun May 10 05:48:14 PDT 2015
> On 10 May 2015, at 14:46, Tim Sutton <tim at kartoza.com> wrote:
> Hi
> What about considering alternative packaging methods? For example making an equivalent of the windows standalone package for Linux.  A long time ago I used to build QGIS and all its dependencies into a directory (e.g. /opt/qgis2.8)  and then use a launcher script to update the library paths to each in that dir with priority over the system libs. The result is something pretty portable and self contained. There are free NSIS like tools for Linux and we would no longer be reliant on which libraries are available on the host system.
> More recently we achieved similar results with Docker (e.g. https://registry.hub.docker.com/u/kartoza/qgis-desktop/ <https://registry.hub.docker.com/u/kartoza/qgis-desktop/>)
> I appreciate that there are many good reasons to use shared libraries on an operating system, but there are also many good reasons not to:
> * cross distribution binaries
> * ability to install multiple concurrent versions of QGIS and know they will work (e.g. we recently had pain when software we wrote depended on QGIS 2.2 but was no longer installable from debian archives)
> * we could provide all the extra goodies that give you a good experience and that are hard to get configured on each distort (grass, saga, OTB, goal with lots of drivers)
> IIRC gdal used to follow this route in the past, and other non FOSS packages like Google Earth etc do too.
> In our PSC thread referred to by Anita below, it became apparent that a lot of people will have a hard time if we jump to Qt5 & Python 3 as a requirement, so we should look for approaches (such, as but not necessarily,  the one above) that provide use some level of independence from the underlying OS and its provisioned packages.
> Also much as I love debian, lets keep some perspective, it is probably a very small part of our established user base (the bulk being on Windows) and it does’t make sense to me to make the majority of users unhappy to keep the minority happy.
> In our road map for migration from QGIS 2.x to 3.x we should definitely plan on supporting 2.x for an extended period in order to allow users and developers to migrate their work to the new platform. so any approach which implies a hard cut off of 2.x support would be suboptimal in my opinion.
My apologies I missed the part about a 2 year transition period from Sebastiaan - which probably negates part of my message above.
Regards
Tim
> Last thought: I wonder if debian plans on supporting the new snappy package format from Ubuntu which I believe will be used for desktop packages too from 15.10 (in addition to deb packages).
> Regards
> Tim
>> On 10 May 2015, at 14:16, Anita Graser <anitagraser at gmx.at <mailto:anitagraser at gmx.at>> wrote:
>> On Sun, May 10, 2015 at 1:45 PM, Paolo Cavallini <cavallini at faunalia.it <mailto:cavallini at faunalia.it>> wrote:
>> Seems a rather serious issue. Shouldn't we reconsider our roadmap accordingly?
>> ​I don't seem to be able to find any dates mentioned in the linked resources. When (date) will Debian remove Qt4?
>> This basically warms up our discussion on http://lists.osgeo.org/pipermail/qgis-psc/2015-April/002974.html <http://lists.osgeo.org/pipermail/qgis-psc/2015-April/002974.html>
>> Best wishes,
>> Anita
>> All the best.
>> Il 10 maggio 2015 11:25:23 CEST, Sebastiaan Couwenberg <sebastic at xs4all.nl <mailto:sebastic at xs4all.nl>> ha scritto:
>> -----BEGIN PGP SIGNED MESSAGE-----
>> Hash: SHA512
>> On 05/10/2015 10:51 AM, Matthias Kuhn wrote:
>>  Hi
>>  On 05/09/2015 03:28 PM, Paolo Cavallini wrote:
>>  Il 09/05/2015 12:38, Sebastiaan Couwenberg ha scritto:
>>  How feasible is switching to Python 3?
>>  I believe this would be a huge issue: most or all plugins will
>>  not work, both the internal and the external ones, so our qgis
>>  will be badly lame. Thanks for raising this point.
>>  There will probably be no PyQt4/Qt5 package but only a PyQt5/Qt5
>>  package? If there's a
>> PyQt4/Qt5 package the upgrade process should
>>  be rather painless. If there's none, all plugins will need an
>>  update anyway and IMO the two changes PyQt5 and Python 3 should be
>>  grouped. Sebastiaan, do you know anything about this package?
>> I'm not involved in the Python or PyQt packaging, so I have no
>> intimate knowledges of those packages.
>> Both the python-qt4 [1] and pyqt5 [2] packages in Debian have the same
>> people involved. They may be willing to provide a python-qt4 package
>> built with qt5.
>> [1] https://tracker.debian.org/pkg/python-qt4 <https://tracker.debian.org/pkg/python-qt4>
>> [2] https://tracker.debian.org/pkg/pyqt5 <https://tracker.debian.org/pkg/pyqt5>
>>  The other issue is that there's a rather big dependency on
>>  QtWebkit currently. We are
>> struggling already with that on
>>  Android. Alternatives * QtWebEngine is the future but only
>>  available starting from Qt 5.4. So this is not an option now. *
>>  QLabel/QML: Where it's only used for richtext, a QLabel can be
>>  used. Where there's javascript involved it may be worth
>>  investigating the use of QML.
>> The planned removal of the Qt4 WebKit component in Debian is the
>> primary reason to switch to Qt5. Sticking to the Qt5 Webkit until Qt
>> 5.4 is widely available seems like the road of least resistance.
>> Kind Regards,
>> Bas
>>  GPG Key ID: 4096R/6750F10AE88D4AF1
>> Fingerprint: 8182 DE41 7056 408D 6146  50D1 6750 F10A E88D 4AF1
>> -----BEGIN PGP SIGNATURE-----
>> Version: GnuPG v2
>> iQIcBAEBCgAGBQJVTyQDAAoJEGdQ8QrojUrxg6kP/Aj8sSsq6eOSG5EKQbbzG2YP
>> xazhDxSbrPJGKql2LaPDOwMb5ChlkTQUi13SZi9Y3B6iUU0IQ11B8zvsTDz+qUC5
>> t3srte+XyJDCDky7gLhRWIikm92F3lusfyrk0t3MCDVdetvt15k3kEUH2M7Nt3jD
>> t1FzhypFVbxLSR7S1a7oM+fy9wp3Z301yYwnpAj8OdhCPL9XM9BxHg2g88hydYMC
>> L/4KdWO3i82HTUsAO1iG6CtY+oYc0a9EL0pelRtcV+icvDycgID1+As/PZrgA3sN
>> 990HWsT4PUgeO2dISte5NtQcLzZw3GrKDiwU3VCU2Zaa2JZWYbKmbHtLWPQIgjMD
>> Tf6hw9QJORIVP58m1I9loF+fT0emBp5fe6FcoIiSAKfLNEVYNJRRMz7y/4Nm4T9p
>> ALnwgSvJQdNpPx5KluPOg4QecCCkmWj8xQ7IpuFVcpxLMrINGKRokzamL5mzHFFW
>> fSkO/zE6lYWeXX8SiT/suavpWi1hQOxqXGRLy0KBeNRSqGywVDQAqxzt3+LWKwZs
>> 8cAv9ySdQqmx2GLOUIzkl8g/zfwudI9WN1/n/oLl2GZ5GIGS9yZgka+N1VrFvAb3
>> gcd3hQxyMxnYBvJ98eLEUlHuNgp9Y74QX4Ap6i8ss53WtTQG+dcBFjrJDFvaU2GO
>> QzV9i13DJiKUdDj6/Lx8
>> =3Ioh
>> -----END PGP SIGNATURE-----
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer <http://lists.osgeo.org/mailman/listinfo/qgis-developer>
>> http://faunalia.eu <http://faunalia.eu/>/
>> Sent from mobile, sorry for being short
> <KartozaLogo160x66.png>
> Tim Sutton
> Visit http://kartoza.com <http://kartoza.com/> to find out about open source:
> * Desktop GIS programming services
> * Geospatial web development
> * GIS Training
> * Consulting Services
> Skype: timlinux Irc: timlinux on #qgis at freenode.net <http://freenode.net/>
> Tim is a member of the QGIS Project Steering Committee
> Kartoza is a merger between Linfiniti and Afrispatial
Tim Sutton
* GIS Training
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150510/10887a79/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150510/10887a79/attachment-0001.png>
