[Qgis-developer] [GRASS-dev] QGIS GRASS Plugin Upgrade Crowdfunding
Radim Blazek
radim.blazek at gmail.com
Tue May 19 03:15:42 PDT 2015
On Tue, May 19, 2015 at 11:11 AM, Paolo Cavallini <cavallini at faunalia.it> wrote:
> Il 18/05/2015 18:06, Radim Blazek ha scritto:
>> BTW, raster/vector import via browser is in master (pushed today), you can test.
> confirmed, both vectors and rasters (all G6) work fine. vectors look
> very fast.
> I see a double entry, one with the usual folder icon showing the full
> content, and one with grass logo showing only the layers: is this a
> temporary solution, or is it made on purpose?
It is intention, since the browser very beginning. The idea is that
the directories should not be hidden from users even if representing
specific provider data structure. For example, the user may want to
open a dbf table from GRASS location using OGR provider. Do you have
suggestions how represent GRASS locations better in the browser?
> Thanks a lot.
> BTW: adding vectors result in a double label in the TOC (vector
> vector1), I suppose to show which layer has been loaded.
I'll fix that.
Radim
> A bit confusing, however.
> Thanks.
> Paolo Cavallini - www.faunalia.eu
> QGIS & PostGIS courses: http://www.faunalia.eu/training.html
> Qgis-developer mailing list
