[Qgis-developer] Problem with the MySQL/GDAL implementation in QGIS
Jürgen E. Fischer
jef at norbit.de
Fri May 22 04:42:35 PDT 2015
Hi Pavol,
On Thu, 21. May 2015 at 12:37:49 +0200, Pavol Hnila wrote:
> Is there a chance that someone corrects this particular code for the next
> release?
Check current master. The commit 7a629ad from Sandro Mani should cure the
problem. I also should help with other performance problem introduced by the
reopening of the OGR data source on each layer feature iteration.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
QGIS release manager (PSC) Germany IRC: jef on FreeNode
Desc: Digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150522/5b3e61ab/attachment.pgp>
