[Qgis-developer] Layers and Browser dock widget icons
Larry Shaffer larrys at dakotacarto.com
Fri May 29 08:53:57 PDT 2015
Hi Matthias,
I'm not understanding that referenced calculation. The fixed number you
multiply the dpi against is platform-specific, yes?
I would be interested in a Qt4-based black box function to manage this
high-rez scaling.
For reference, though a bit dated:
http://blog.qt.io/blog/2013/04/25/retina-display-support-for-mac-os-ios-and-x11/
Regards,
Larry Shaffer
Dakota Cartography
Black Hills, South Dakota
On Fri, May 29, 2015 at 5:16 AM, Matthias Kuhn <matthias at opengis.ch> wrote:
>  Having more SVG icons helps a lot to make the interface look good
> (despite the fact that some graphics designer may object that there's no
> hinting)
> For reference, this code is used in QField to calculate button sizes and
> may as well be used to calculate the default icon size device independently:
> https://github.com/opengisch/QField/blob/master/src/qgismobileapp.cpp#L110-L113
> Cheers
> On 05/29/2015 01:08 PM, Mathieu Pellerin wrote:
> I'd say the related changes committed within the last 72 hours helped a
> lot in that regard. For one, the icon refresh moved away from 16 x 16 png
> icons to SVG graphics. In addition, the icon size for dock tool buttons are
> now taking into account the user preferred icon size.
> On Fri, May 29, 2015 at 3:05 PM, Alessandro Pasotti <apasotti at gmail.com>
> wrote:
>>     Please consider HiDPI screens when planning icon sizes, at least
>> they should be configurable, there is still a settings option for icon
>> sizes.
>>  At the HF we discussed about the different options, one is to add
>> options like
>>  very small
>>  small
>>  normal
>>  big
>>  huge
>>  instead of the px size, this should scale nicely converting sizes to
>> actual pixels according to DPI.
>> 2015-05-29 2:34 GMT+02:00 Mathieu Pellerin <nirvn.asia at gmail.com>:
>>> Larry,
>>> As Nyall mentioned, icon size of the dock tool button will go back to 16
>>> x 16 by default. That'll make things look the same as before.
>>> That said, the border on the buttons (no present on other OSes) aren't
>>> very nice. It might be worth adding a style specifically for os x to remove
>>> those.
>>>  On 29 May 2015 05:37, "Nyall Dawson" <nyall.dawson at gmail.com> wrote:
>>>> On 29 May 2015 5:55 am, "Larry Shaffer" <larrys at dakotacarto.com> wrote:
>>>> > Hi,
>>>> > The new icons for the Layers and Browser docks look good, but now the
>>>> sizing and spacing looks awkward when compared to the main toolbars (see 0,
>>>> 1 screen snaps), especially on Mac. What's the likelihood that we can
>>>> switch those over from QToolButtons to a actions on a QToolBar instead for
>>>> the upcoming release? These docks would then look similar to the Console's
>>>> QToolBar (see either screen snap).
>>>> There's some discussion on the pull request regarding this, see:
>>>> https://github.com/qgis/QGIS/pull/2071#issuecomment-106283486
>>>> The plan is to drop the icon/button sizes down a level (should then
>>>> match the previous appearance).
>>>> Nyall
>>>>  _______________________________________________
>>>> Qgis-developer mailing list
>>>> Qgis-developer at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Alessandro Pasotti
>> w3:   www.itopen.it
> Qgis-developer mailing listQgis-developer at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150529/9f277f47/attachment.html>
