[Qgis-developer] Layers and Browser dock widget icons
Matthias Kuhn
matthias at opengis.ch
Sat May 30 01:07:41 PDT 2015
Hi Larry,
Actually I haven't written these lines, they come from the GSoC 2012
work by Ramón Carillo on QGIS for Android.
I think the fixed number there relates to the "/ 160" from the following
page which takes a 160 dpi screen as reference [1] while our code uses a
130 dpi screen as reference.
Anyway, multiplying a size with dp afterwards gives a number of pixels
which is larger on denser displays.
Thinking about it now, we should probably try to be compatible with the
value returned by the corresponding Qt5 method. [2]
Best,
Matthias
[1] http://stackoverflow.com/a/8478997/2319028
[2] http://doc.qt.io/qt-5/qwindow.html#devicePixelRatio
On 05/29/2015 05:53 PM, Larry Shaffer wrote:
> Hi Matthias,
> I'm not understanding that referenced calculation. The fixed number
> you multiply the dpi against is platform-specific, yes?
> I would be interested in a Qt4-based black box function to manage this
> high-rez scaling.
> For reference, though a bit dated:
> http://blog.qt.io/blog/2013/04/25/retina-display-support-for-mac-os-ios-and-x11/
> Regards,
> Larry Shaffer
> Dakota Cartography
> Black Hills, South Dakota
> On Fri, May 29, 2015 at 5:16 AM, Matthias Kuhn <matthias at opengis.ch
> <mailto:matthias at opengis.ch>> wrote:
> Having more SVG icons helps a lot to make the interface look good
> (despite the fact that some graphics designer may object that
> there's no hinting)
> For reference, this code is used in QField to calculate button
> sizes and may as well be used to calculate the default icon size
> device independently:
> https://github.com/opengisch/QField/blob/master/src/qgismobileapp.cpp#L110-L113
> Cheers
> On 05/29/2015 01:08 PM, Mathieu Pellerin wrote:
>> I'd say the related changes committed within the last 72 hours
>> helped a lot in that regard. For one, the icon refresh moved away
>> from 16 x 16 png icons to SVG graphics. In addition, the icon
>> size for dock tool buttons are now taking into account the user
>> preferred icon size.
>> On Fri, May 29, 2015 at 3:05 PM, Alessandro Pasotti
>> <apasotti at gmail.com <mailto:apasotti at gmail.com>> wrote:
>> Please consider HiDPI screens when planning icon sizes, at
>> least they should be configurable, there is still a settings
>> option for icon sizes.
>> At the HF we discussed about the different options, one is to
>> add options like
>> very small
>> small
>> normal
>> big
>> huge
>> instead of the px size, this should scale nicely converting
>> sizes to actual pixels according to DPI.
>> 2015-05-29 2:34 GMT+02:00 Mathieu Pellerin
>> <nirvn.asia at gmail.com <mailto:nirvn.asia at gmail.com>>:
>> Larry,
>> As Nyall mentioned, icon size of the dock tool button
>> will go back to 16 x 16 by default. That'll make things
>> look the same as before.
>> That said, the border on the buttons (no present on other
>> OSes) aren't very nice. It might be worth adding a style
>> specifically for os x to remove those.
>> On 29 May 2015 05:37, "Nyall Dawson"
>> <nyall.dawson at gmail.com <mailto:nyall.dawson at gmail.com>>
>> wrote:
>> On 29 May 2015 5:55 am, "Larry Shaffer"
>> <larrys at dakotacarto.com
>> <mailto:larrys at dakotacarto.com>> wrote:
>> > Hi,
>> > The new icons for the Layers and Browser docks look
>> good, but now the sizing and spacing looks awkward
>> when compared to the main toolbars (see 0, 1 screen
>> snaps), especially on Mac. What's the likelihood that
>> we can switch those over from QToolButtons to a
>> actions on a QToolBar instead for the upcoming
>> release? These docks would then look similar to the
>> Console's QToolBar (see either screen snap).
>> There's some discussion on the pull request regarding
>> this, see:
>> https://github.com/qgis/QGIS/pull/2071#issuecomment-106283486
>> The plan is to drop the icon/button sizes down a
>> level (should then match the previous appearance).
>> Nyall
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> <mailto:Qgis-developer at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Alessandro Pasotti
>> w3: www.itopen.it <http://www.itopen.it>
>> Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150530/f655609d/attachment-0001.html>
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150530/f655609d/attachment-0001.pgp>
