[Qgis-developer] Errors with some Processing algorithm
Arnaud Morvan arnaud.morvan at camptocamp.com
Mon Oct 12 04:50:09 PDT 2015
Le 12/10/2015 12:15, matteo a écrit :
> Hi all,
> I'm doing some test with Processing and I'm facing some problem with
> some algorithm:
> * Create grid (QGIS).. each time I try to create a grid I receive this
> error:
> Grid instance has no attribute 'TYPES' See log for more details
> while using the same algorithm from the Vector menu of QGIS no problem
This is also a lack due to my recent changes in the translation strings
This can be fixed by https://github.com/qgis/QGIS/pull/2366
> * Zonal statistics: input raster (DEM) and a polygon vector (I'm sure
> the CRS are the same). This is the error:
> in method 'SpatialReference_ImportFromProj4', argument 2 of type 'char
> *' See log for more details
> same thing of above: the algorithm works if called from the QGIS menu.
Error seems to come from here :
https://github.com/qgis/QGIS/commit/9fc1b48bf3ff46c2210bdbbc4d9353033da66f6a#commitcomment-13714783
This should also affect HypsometricCurves
@m-kuhn: Can you confirm that we can revert unicode() => str() on this
specific lines
I'm not confortable with unicode object and binaries binding like osgeo._osr
Arnaud
> I'll continue testing..
> Thanks
> Matteo
> Qgis-developer mailing list
