[Qgis-developer] Vertex editor
Denis Rouzaud
denis.rouzaud at gmail.com
Sun Sep 13 22:19:39 PDT 2015
On 09/13/2015 11:32 PM, Nyall Dawson wrote:
> On 14 September 2015 at 07:07, Saber Razmjooei
> <saber.razmjooei at lutraconsulting.co.uk> wrote:
>> The new changes assume:
>> - User always wants to move a vertex
>> - Only one single vertex is selected
>> But in general, the node tool is also heavily used for deleting, adding and moving vertices. With the new behaviour it is a bit confusing for users how the other tasks can be done, when it gets automatically locked on a single node.
> There's a long blocker list relating to regressions in the map tools, eg:
> - deleting a node: the rubber band is not removed
> - deleting a node: when finished, the next node should be pre-selected
> (this pre-selection should by synchro with the table view selection
> model).
> - right-click should cancel the edition of the node (but keeps it pre-selected)
> - for point layers, there is no visual feedback of the point being
> moved (no rubberband)
> - editing in table view: changes should be applied to the rubberband
> on keypress (not on editing finished), and when editing is finished it
> should ends the digitizing (clear rubberband)
> ( all from http://hub.qgis.org/issues/13276)
> - split tool errors: http://hub.qgis.org/issues/13273 and
> http://hub.qgis.org/issues/13347
> - inability to add parts to null geometries - refs
> http://hub.qgis.org/issues/12885
> I tried to do some digitising in master last week and honestly it was
> unusable for geometry editing. Lots of regressions and unexpected
> behaviour compared to the smooooth editing machine that 2.8 is! I
> understand master is a work-in-progress, but can we get some
> confirmation of which issues will be addressed prior to 2.14?
> Marco/Denis? If there's no funding to address these then I think they
> should be prioritised for the 2.14 bug fixing period.
All these issues shall be fixed prior to the release.
Marco, do you have any schedule regarding this?
> Nyall
> Qgis-developer mailing list
