[Qgis-developer] crash on deleting a column (virtual field)
Giuseppe Sucameli brush.tyler at gmail.com
Tue Sep 22 13:55:25 PDT 2015
Hi Salvatore,
I can reproduce the issue you reported, I get segfault following those
steps.
Please, file a new ticket for it, AFAICS it's not related to the other
issue.
Ciao.
Giuseppe
On Tue, Sep 22, 2015 at 3:06 PM Salvatore Larosa <lrssvtml at gmail.com> wrote:
> Hi Tom,
> On Tue, Sep 22, 2015 at 10:02 AM, Tom Chadwin <tom.chadwin at nnpa.org.uk>
> wrote:
> > Hi Salvatore
> > Following the steps in Pedro's ticket does *not* crash for me. However,
> I'll
> > ask some questions to clarify:
> > 1. I did not select "Virtual field", as that was not mentioned in the
> ticket
> I added a comment to the issue with the steps already mentioned in this
> trhead.
> > 2. I only gave a static value for the contents o the field, rather than
> an
> > expression - does this only happen with more complex expressions?
> yes it occurs with any value, not needed a complex expression.
> > 3. I did not close the attribute table between creating the new field and
> > deleting it
> correct, you have to keep attribute dialog open
> > Does anyone else *not* get a crash following the steps in
> > https://hub.qgis.org/issues/13366?
> Actually there are two different issue apparently,  the first one
> (Pedro's issue) happens with native field, but it was already fixed
> [0],
> the second one (mine) happens when creating a virtual field by field
> calculator and then deleting it.
> Maybe should I file a new ticket for it?
> Thanks for your feedback.
> Salvatore Larosa
> linkedIn: http://linkedin.com/in/larosasalvatore
> twitter: @lrssvt
> skype: s.larosa
> IRC: lrssvt on freenode
> Qgis-developer mailing list
Giuseppe Sucameli
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150922/26de35e8/attachment.html>
