[Qgis-developer] crash on deleting a column (virtual field)
Salvatore Larosa lrssvtml at gmail.com
Tue Sep 22 15:12:26 PDT 2015
Hi Giuseppe,
On Tue, Sep 22, 2015 at 10:55 PM, Giuseppe Sucameli <brush.tyler at gmail.com>
wrote:
> Hi Salvatore,
> I can reproduce the issue you reported, I get segfault following those
> steps.
thank you Giuseppe for having tried it, maybe I am managed to find a fix
for it.
> Please, file a new ticket for it, AFAICS it's not related to the other
> issue.
I will do.
Saluti,
-SL
> Ciao.
> Giuseppe
> On Tue, Sep 22, 2015 at 3:06 PM Salvatore Larosa <lrssvtml at gmail.com>
wrote:
>> Hi Tom,
>> On Tue, Sep 22, 2015 at 10:02 AM, Tom Chadwin <tom.chadwin at nnpa.org.uk>
>> wrote:
>> > Hi Salvatore
>> > Following the steps in Pedro's ticket does *not* crash for me. However,
>> > I'll
>> > ask some questions to clarify:
>> > 1. I did not select "Virtual field", as that was not mentioned in the
>> > ticket
>> I added a comment to the issue with the steps already mentioned in this
>> trhead.
>> > 2. I only gave a static value for the contents o the field, rather than
>> > an
>> > expression - does this only happen with more complex expressions?
>> yes it occurs with any value, not needed a complex expression.
>> > 3. I did not close the attribute table between creating the new field
>> > and
>> > deleting it
>> correct, you have to keep attribute dialog open
>> > Does anyone else *not* get a crash following the steps in
>> > https://hub.qgis.org/issues/13366?
>> Actually there are two different issue apparently, the first one
>> (Pedro's issue) happens with native field, but it was already fixed
>> [0],
>> the second one (mine) happens when creating a virtual field by field
>> calculator and then deleting it.
>> Maybe should I file a new ticket for it?
>> Thanks for your feedback.
>> Salvatore Larosa
>> linkedIn: http://linkedin.com/in/larosasalvatore
>> twitter: @lrssvt
>> skype: s.larosa
>> IRC: lrssvt on freenode
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Giuseppe Sucameli
Salvatore Larosa
twitter: @lrssvt
skype: s.larosa
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150923/20ad48a2/attachment.html>
