[Qgis-developer] crash on deleting a column (virtual field)
Giuseppe Sucameli brush.tyler at gmail.com
Sat Sep 26 11:16:50 PDT 2015
Hi Salvatore,
I'm unable to find the ticket no., I would like to know if the virtual
field issue is fixed
in current master (today I'm unable to build the master on Ubuntu 14.04 due
to an
error linking geos library, related to the following changes [1]).
Did you have time to have a look at it?
Otherwise, if you need help in crushing this bug, please just ask.
Cheers!
Giuseppe
[1]
https://github.com/qgis/QGIS/commit/e9e638f6f40baf22f4d0667a98fb8e034fefd78c
On Wed, Sep 23, 2015 at 12:12 AM Salvatore Larosa <lrssvtml at gmail.com>
wrote:
> Hi Giuseppe,
> On Tue, Sep 22, 2015 at 10:55 PM, Giuseppe Sucameli <brush.tyler at gmail.com>
> wrote:
> > Hi Salvatore,
> > I can reproduce the issue you reported, I get segfault following those
> > steps.
> thank you Giuseppe for having tried it, maybe I am managed to find a fix
> for it.
> > Please, file a new ticket for it, AFAICS it's not related to the other
> > issue.
> I will do.
> Saluti,
> -SL
> > Ciao.
> > Giuseppe
> > On Tue, Sep 22, 2015 at 3:06 PM Salvatore Larosa <lrssvtml at gmail.com>
> wrote:
> >> Hi Tom,
> >> On Tue, Sep 22, 2015 at 10:02 AM, Tom Chadwin <tom.chadwin at nnpa.org.uk>
> >> wrote:
> >> > Hi Salvatore
> >> > Following the steps in Pedro's ticket does *not* crash for me.
> However,
> >> > I'll
> >> > ask some questions to clarify:
> >> > 1. I did not select "Virtual field", as that was not mentioned in the
> >> > ticket
> >> I added a comment to the issue with the steps already mentioned in this
> >> trhead.
> >> > 2. I only gave a static value for the contents o the field, rather
> than
> >> > an
> >> > expression - does this only happen with more complex expressions?
> >> yes it occurs with any value, not needed a complex expression.
> >> > 3. I did not close the attribute table between creating the new field
> >> > and
> >> > deleting it
> >> correct, you have to keep attribute dialog open
> >> > Does anyone else *not* get a crash following the steps in
> >> > https://hub.qgis.org/issues/13366?
> >> Actually there are two different issue apparently, the first one
> >> (Pedro's issue) happens with native field, but it was already fixed
> >> [0],
> >> the second one (mine) happens when creating a virtual field by field
> >> calculator and then deleting it.
> >> Maybe should I file a new ticket for it?
> >> Thanks for your feedback.
> >> Salvatore Larosa
> >> linkedIn: http://linkedin.com/in/larosasalvatore
> >> twitter: @lrssvt
> >> skype: s.larosa
> >> IRC: lrssvt on freenode
> >> _______________________________________________
> >> Qgis-developer mailing list
> >> Qgis-developer at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Giuseppe Sucameli
> Salvatore Larosa
> twitter: @lrssvt
> skype: s.larosa
Giuseppe Sucameli
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150926/8593be45/attachment.html>
