[Qgis-developer] QGSrelationeditorwidget in custom form
Matthias Kuhn matthias at opengis.ch
Wed Sep 23 23:01:32 PDT 2015
Hi Luca,
The width is not configurable with a property on the top widget. I
assume's it would be with a stylesheet (the object name of the widget is
"listViewWdg").
The subform represents another layer, so you can connect to the other
layer's signals.
Matthias
On 09/23/2015 11:29 PM, Luca Lanteri wrote:
> Hi,
> I'm using the QGSrelationeditorwidget in a custom form with qtcreator.
> It works very well (very powerful feature !) but I have some problem:
> The first is that I can't fit my subform due to the large amount of
> data present inside of it. I wondering if it were possible to set the
> width of the leftmost column (where there is the selection of the
> related record) because it is huge and it use the main part of my
> form. I try to see in the properties of the widget but unsuccessfully.
> The second problem is that I can't activate my custom objects into the
> subform when I switch to editing mode because I can't find the proper
> signal. Is there a signal
> for QGSrelationeditorwidget that say to me when the subform goes in
> editing mode ?
> Thank in advance
> Luca
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150924/462bcbcf/attachment.html>
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150924/462bcbcf/attachment.pgp>
