[Qgis-developer] Warning from DigitizingTools about CRS mismatch
Casper Børgesen (CABO)
CABO at NIRAS.DK
Fri Apr 8 01:10:04 PDT 2016
Hi!
I have a user who constantly get a yellow warning from QGIS when he enables editing on set of specific shape files. The message is:
DigitizingTools: Amend Line is disabled because layer CRS and project CRS do not match!
The project CRS is EPSG:25832. The shape file has the following .prj file:
PROJCS["ETRS_1989_UTM_Zone_32N",GEOGCS["GCS_ETRS_1989",DATUM["D_ETRS_1989",SPHEROID["GRS_1980",6378137.0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],PARAMETER["False_Easting",500000.0],PARAMETER["False_Northing",0.0],PARAMETER["Central_Meridian",9.0],PARAMETER["Scale_Factor",0.9996],PARAMETER["Latitude_Of_Origin",0.0],UNIT["Meter",1.0]]
In "layer properties/General/Coordinate reference system", QGIS displays "Selected CRS (EPSG: 3044, ETRS89 / ETRS-TM32".
If he enables editing on a shape file with the following .prj file, it doesn't happen:
PROJCS["ETRS89_UTM_zone_32N",GEOGCS["GCS_ETRS_1989",DATUM["D_ETRS_1989",SPHEROID["GRS_1980",6378137,298.257222101]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",9],PARAMETER["scale_factor",0.9996],PARAMETER["false_easting",500000],PARAMETER["false_northing",0],UNIT["Meter",1]]
The strange thing is that this only happens on his computer not on a couple of other machines we have tried on.
If there indeed is a CRS mismatch it make sense, but he is the only of our users experiencing this.
Regards, Casper
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160408/d5f0d5bb/attachment.html>
