[Qgis-developer] Add a WHERE clause to field calculator
Neumann, Andreas
a.neumann at carto.net
Fri Apr 8 04:53:43 PDT 2016
Would it be possible to add a "WHERE" clause to the field calculator?
Currently, if you want to update a subset of the records you would have
to do a two-step producedure:
1. Make a selection
2. Open field calculator and use the checkbox "only update selected
features".
I think, in some workflows it would be more efficient if one had a text
input area where one can enter a WHERE clause and the field calculator
would respect the WHERE clause, if filled in. It would reduce the
two-step operation into a one or 1.5 step operation, so more efficient.
If you have to update based on multiple different subsets it would be
even more efficient.
Would this be a useful enhancement to more users? Esp. for those who
know SQL ;-) ?
Thanks and greetings,
Andreas
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160408/74e20d5f/attachment.html>
