[Qgis-developer] Issue with QGIS server on CentOS - self compiled
Neumann, Andreas a.neumann at carto.net
Wed Aug 10 09:17:27 PDT 2016
I self-compiled QGIS Server (on CentOS 7) and it works fine for
GetCapabilities and GetProjectSettings commands, but fails for GetMap.
In the Apache log I get an error:
libpng warning: Application was compiled with png.h from libpng-1.5.13
libpng warning: Application is running with png.c from libpng-1.2.56
libpng error: Incompatible libpng version in application and library
I checked libpng and there is "libpng-1.5.13" on my machine in
/usr/lib64. Within the gdal source tree (also self-compiled) there is a
is a second version of libpng, which seems to match libpng-1.2.56
Do you have an idea how I can influence the QGIS server fcgi file to
pick up libpng-1.5.13 first?
I tried to set LD_LIBRARY_PATH and set "/usr/lib64" first, so I assumed
it picks up the newer version first. But it still fails ...
Does libgdal.so contain the older version of libpng which conflicts?
Thanks,
Andreas
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160810/4116a984/attachment.html>
