[Qgis-developer] Issue with QGIS server on CentOS - self compiled
Dave Johansen davejohansen at gmail.com
Wed Aug 10 20:24:07 PDT 2016
QGIS is packaged in EPEL, so that would be another option.
https://admin.fedoraproject.org/pkgdb/package/rpms/qgis/
On Wed, Aug 10, 2016 at 10:17 AM, Neumann, Andreas <a.neumann at carto.net>
wrote:
> Hi,
> I self-compiled QGIS Server (on CentOS 7) and it works fine for
> GetCapabilities and GetProjectSettings commands, but fails for GetMap.
> In the Apache log I get an error:
> libpng warning: Application was compiled with png.h from libpng-1.5.13
> libpng warning: Application is running with png.c from libpng-1.2.56
> libpng error: Incompatible libpng version in application and library
> I checked libpng and there is "libpng-1.5.13" on my machine in /usr/lib64.
> Within the gdal source tree (also self-compiled) there is a is a second
> version of libpng, which seems to match libpng-1.2.56
> Do you have an idea how I can influence the QGIS server fcgi file to pick
> up libpng-1.5.13 first?
> I tried to set LD_LIBRARY_PATH and set "/usr/lib64" first, so I assumed it
> picks up the newer version first. But it still fails ...
> Does libgdal.so contain the older version of libpng which conflicts?
> Thanks,
> Andreas
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160810/02d48002/attachment.html>
