[Qgis-developer] Issue with QGIS server on CentOS - self compiled
Dave Johansen davejohansen at gmail.com
Thu Aug 11 08:22:50 PDT 2016
Have you considered using COPR so other could benefit from your work and
potentially help out? (
http://developers.redhat.com/blog/2014/03/11/intro-coprs/ )
There are already a few COPR repos, but a "nightly" one would be a nice
addition for this interested in testing out the latest and greatest. I'm
not sure if the Oracle stuff would run into licensing issues, but if not,
then getting it into the Fedora/EPEL releases and/or a COPR repo would be
nice.
On Thu, Aug 11, 2016 at 6:03 AM, Neumann, Andreas <a.neumann at carto.net>
wrote:
> HI David,
> Thanks - I am aware that there are packages. But there are two
> main reasons why I want to self-compile:
> * being able to use certain configuration options or supporting databases
> that are not supported by the standard package (such as Oracle support)
> * being able to test new features from github regularly
> I still haven't fixed the issue with the two incompatible libpng. Seems to
> be more a runtime issue with Apache fcgi and LD_LIBRARY_PATH. BTW: output
> as JPEG works fine ...
> I will post again if I was able to fix the issue.
> Thanks,
> Andreas
> On 2016-08-11 05:24, Dave Johansen wrote:
> QGIS is packaged in EPEL, so that would be another option.
> https://admin.fedoraproject.org/pkgdb/package/rpms/qgis/
> On Wed, Aug 10, 2016 at 10:17 AM, Neumann, Andreas <a.neumann at carto.net>
> wrote:
>> Hi,
>> I self-compiled QGIS Server (on CentOS 7) and it works fine for
>> GetCapabilities and GetProjectSettings commands, but fails for GetMap.
>> In the Apache log I get an error:
>> libpng warning: Application was compiled with png.h from libpng-1.5.13
>> libpng warning: Application is running with png.c from libpng-1.2.56
>> libpng error: Incompatible libpng version in application and library
>> I checked libpng and there is "libpng-1.5.13" on my machine in
>> /usr/lib64. Within the gdal source tree (also self-compiled) there is a is
>> a second version of libpng, which seems to match libpng-1.2.56
>> Do you have an idea how I can influence the QGIS server fcgi file to pick
>> up libpng-1.5.13 first?
>> I tried to set LD_LIBRARY_PATH and set "/usr/lib64" first, so I assumed
>> it picks up the newer version first. But it still fails ...
>> Does libgdal.so contain the older version of libpng which conflicts?
>> Thanks,
>> Andreas
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160811/853315dd/attachment.html>
