[Qgis-developer] Decoupling core/data and GUI part of widgets in 3.0
Nathan Woodrow
madmanwoo at gmail.com
Tue Aug 30 23:37:59 PDT 2016
I'm a big +1 on that. I will add my notes on a QEP if one is opened
(Hopefully I can be a bit more active in the project after a bit of a break)
- Nathan
On Wed, Aug 31, 2016 at 4:29 PM, Neumann, Andreas <a.neumann at carto.net>
wrote:
> Hi all, Hi Nyall, Matthias and Denis,
> After some discussion with Nyall we stumbled again over the inconvenience
> that widgets in QGIS mix data (core) and GUI part. This effects many places
> in QGIS where you want to address the display value of a widget instead of
> the raw value: QGIS Server (e.g. GetFeatureInfo Requests), Print Composer,
> Labels, Save to Spreadsheet with human readable values, and many more.
> So before people are introducing more and more widgets (which is nice) I
> would suggest to first improve our widget infrastructure for QGIS 3.0 to
> decouple the Core/data part from the GUI part, which would allow code to
> access all widget configuration and properties without having to deal with
> the GUI part of the widget. Nyall mentioned that the symbology rendering
> separates this nicely, but the attribute widgets do not.
> Nyall suggested to do a QEP for that to discuss the implications and how
> this can be cleanly designed.
> Matthias - since you are "the widget guy" - do you want to take a lead on
> this QEP? Or should I ask Nyall?
> Thanks,
> Andreas
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160831/05dbd297/attachment.html>
