[Qgis-developer] Decoupling core/data and GUI part of widgets in 3.0
Richard Duivenvoorde
rdmailings at duif.net
Tue Aug 30 23:48:52 PDT 2016
+1 from me too
As a project we should really take the opportunity of a 3.0 branch to
review this kind of architectural cleanups and focus on a healthy code
base more then on new features for the .0 version, in my opinion.
best off course if core dev's take the lead in this
Regards,
Richard
On 31-08-16 08:37, Nathan Woodrow wrote:
> I'm a big +1 on that. I will add my notes on a QEP if one is opened
> (Hopefully I can be a bit more active in the project after a bit of a break)
> - Nathan
> On Wed, Aug 31, 2016 at 4:29 PM, Neumann, Andreas <a.neumann at carto.net
> <mailto:a.neumann at carto.net>> wrote:
> Hi all, Hi Nyall, Matthias and Denis,
> After some discussion with Nyall we stumbled again over the
> inconvenience that widgets in QGIS mix data (core) and GUI part.
> This effects many places in QGIS where you want to address the
> display value of a widget instead of the raw value: QGIS Server
> (e.g. GetFeatureInfo Requests), Print Composer, Labels, Save to
> Spreadsheet with human readable values, and many more.
> So before people are introducing more and more widgets (which is
> nice) I would suggest to first improve our widget infrastructure for
> QGIS 3.0 to decouple the Core/data part from the GUI part, which
> would allow code to access all widget configuration and
> properties without having to deal with the GUI part of the widget.
> Nyall mentioned that the symbology rendering separates this nicely,
> but the attribute widgets do not.
> Nyall suggested to do a QEP for that to discuss the implications and
> how this can be cleanly designed.
> Matthias - since you are "the widget guy" - do you want to take a
> lead on this QEP? Or should I ask Nyall?
> Thanks,
> Andreas
> Qgis-developer mailing list
> Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> <http://lists.osgeo.org/mailman/listinfo/qgis-developer>
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
