[Qgis-developer] Looking for advices to avoid breaking translated strings
DelazJ delazj at gmail.com
Thu Dec 22 06:14:42 PST 2016
Le jeudi 22 décembre 2016, Matthias Kuhn <matthias at opengis.ch> a écrit :
> Hi Harrissou
> On 12/22/2016 02:31 PM, DelazJ wrote:
>> Let's take a reported typo: "cellsize" instead of "cell size". If I
>> check Transifex, we currently have 19 strings that contain this word. So
>> if the replacements are done in QGIS source files, when these ones are
>> pushed to transifex, these strings will be replaced and because of this
>> tiny difference, the translations already done for ALL languages will be
>> deconnected, hence lost.
> At least the translated text should be proposed to the translator if the
> source string is still similar. So it does not need to be completely
> rewritten.
Sorry I wasn't precise enough. I didn't mean all the translations in QGIS
will be lost. Unchanged strings will for sure keep their translation. I was
referring to these 19 strings which have changed.
For what I've seen, Transifex will keep them along and propose them because
they are translation for a very close text but no matching will be done as
they don't match. Someone needs to do the click.
Harrissou
>> I've been thinking about a process and wonder if it'll work (and will
>> require someone with write access):
>> - Pull translations from Transifex
>> - have a PR in which besides fixing strings in the source code, their
>> duplicate in /i18n folder are also fixed. In this case the .ts file
>> contains the cleaned text linked to the existing translation
>> - then merge the commit
>> - and push it again to transifex
> I am not sure if in this case the whole transifex translation will be
> overwritten and any new translations added between opening the pull
> request and pushing to transifex will be lost.
> It would probably be safer if it would be merged first and then someone
> takes care of doing
>  tx pull
>  ... adjust translations ...
>  tx push (-t I think?)
> in a short timeframe to reduce the risk of collisions
> Matthias
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20161222/48e87525/attachment.html>
